Video of how to apply Mylar aileron seals?
Old April 9th 16, 03:05 AM posted to rec.aviation.soaring
Soartech
Default Video of how to apply Mylar aileron seals?
I have searched Google, YouTube and Vimeo and cannot locate any video of someone applying Mylar control surface gap coverings. If someone out there has videoed this could you please upload it to YouTube or Vimeo?
Thanks. I don't want to attempt this until I've seen it done.
Old April 9th 16, 03:44 AM posted to rec.aviation.soaring
JS
The videos have probably all been removed due to profanity regulations.
Old April 9th 16, 06:15 AM posted to rec.aviation.soaring
A few years ago Jay Campbell wrote a article in Soaring Magazine. It was well done with pictures. The article was in the November 2011 issue.
C5
Old April 9th 16, 06:16 AM posted to rec.aviation.soaring
Dennis Vreeken
Not as bad as it sounds , take it slow and use a pencil and a long straight edge. Do not rush
Old April 9th 16, 01:51 PM posted to rec.aviation.soaring
Jays' article is very good. The only thing I change in his technique, is to get all the glue from the double sticky tape off by rubbing your thumb firmly on it that you can. Then clean the rest of it off with the 3m Adhesive remover.
If you soak it like Jay is suggesting then you can end up with big soft glue buggers that are hard to keep out of the aileron gap.
Kevin
92
Old April 10th 16, 01:33 AM posted to rec.aviation.soaring
Soartech
Thanks guys. I will download the November 2011 issue and try to keep the swearing to a minimum.
Mylar aileron and flap seals Grider Pirate[_2_] Soaring 12 June 2nd 12 01:52 AM
Mylar seals for PIK20D culverflyer Soaring 5 May 19th 04 06:25 PM
mylar seals wing to flap/ Aileron culverflyer Soaring 2 May 5th 04 02:52 PM
ZZ Mylar seals Mike Soaring 3 March 29th 04 03:45 PM
mylar seals D.A.L Soaring 1 February 23rd 04 07:15 PM
