Oudie 2 to Cambridge 302
Old April 17th 16, 07:43 PM posted to rec.aviation.soaring
Default Oudie 2 to Cambridge 302
Hi, anyone have any experience on how to connect oudie to 302 and use the 5V from the 302 to power oudie? The standard cable doesnt seem to support this option.
Many thanks!
Thijs Paré
Old April 19th 16, 05:09 AM posted to rec.aviation.soaring
Paul Remde
Hi Thijs,
I offer to options for connecting an Oudie to a 302. Note that a serial
data voltage converter is required because the Oudie talks TTL serial (low
voltage) and the 302 talks RS-232 serial (higher voltage).
- Use the supplied Oudie Cable Kit and RJ45 to DB-9m adapter
http://www.cumulus-soaring.com/seeyo...udie-Cable-Kit
configured as shown he
http://www.cumulus-soaring.com/seeyo...pter-RJ45-DB9m
The Oudie power/data cable must be powered with 12 V to work. It can't get
the 12V from the Oudie.
- Use a Goddard Oudie-PS5a-1 cable.
http://www.cumulus-soaring.com/goddard.htm#Oudie-PS5a-1
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
______________________________________
option.
Many thanks!
Thijs Paré
Oudie to Cambridge HGXC[_2_] Soaring 19 May 4th 16 08:35 AM
oudie Steve Hunt[_2_] Soaring 0 July 7th 11 08:58 AM
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
Cambridge 302 & PDA -- Value of adding Cambridge 303? V1 Soaring 5 July 31st 07 03:51 AM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 5th 04 11:22 PM
