1-26 1000K Attempt In Progress
Old April 19th 16, 01:25 PM posted to rec.aviation.soaring
Papa3[_2_]
Default 1-26 1000K Attempt In Progress
Ron Schwartz got off tow a little before 7 a.m. after a launch from Blairstown. He has a declared 1000K 3 turnpoint in the box. While the synoptic picture isn't classic, it seems to be working. Local winds picked up shortly after sunrise and reporting stations along the route are currently starting to swing around to the northwest. Karl Striedieck reports solid winds at Eagle Field, which is about the midpoint of the task area. Ron buys some time by getting his first lap in on the local ridge before heading south across the Susquehanna and Potomac rivers later in the day. If you listen carefully, you can hear the oil canning even now...
P3
Old April 19th 16, 01:28 PM posted to rec.aviation.soaring
N97MT
P3
Wow. Truly amazing, I wish him the best of success.
Old April 19th 16, 01:46 PM posted to rec.aviation.soaring
Tony[_5_]
Go Ron go!
Old April 19th 16, 02:56 PM posted to rec.aviation.soaring
+1, that will be a long day in a 1-26.......
Old April 19th 16, 02:09 PM posted to rec.aviation.soaring
Papa3[_2_]
After 2 hours Ron has about 100 miles in the bag. Looks like the winds are coming around throughout central and eastern PA. He will be close to 200 miles before the first big transition. You can watch his progress on the SSA Sailplane Tracker. Next update late morning.
Old April 19th 16, 03:02 PM posted to rec.aviation.soaring
Dave Nadler
On Tuesday, April 19, 2016 at 9:09:24 AM UTC-4, Papa3 wrote:
...You can watch his progress on the SSA Sailplane Tracker.
Except, the SSA Sailplane Tracker is currently displaying a blank screen...
Aaarrggg...
Old April 19th 16, 03:04 PM posted to rec.aviation.soaring
Tango Eight
Aaarrggg...
Works for me...
T8
Old April 19th 16, 03:14 PM posted to rec.aviation.soaring
Works on my iPad........
Old April 19th 16, 02:10 PM posted to rec.aviation.soaring
Go get it Ron!!!
Kevin
92
Old April 19th 16, 03:46 PM posted to rec.aviation.soaring
At 10:30, the surface winds at University Park airport are reported as 350 degrees and 10 kts. Here at Ridge Soaring Gliderport, the winds are very light. Pilots are waiting.
Tom Knauff
18yr old flies 1000k Ventus_a Soaring 8 December 15th 10 08:23 PM
How much water for a 1000K attempt? ttaylor at cc.usu.edu Soaring 16 August 11th 05 11:07 AM
1000k comp task Mel Dawson Soaring 0 July 5th 05 08:22 PM
Youngest 1000k...? Luke Roberts Soaring 4 March 26th 05 03:12 AM
1000K Questions Brian Iten Soaring 7 April 29th 04 02:05 PM
