Belfort Instrument- Quality Products by Quality People
Old April 20th 16, 05:42 PM posted to rec.aviation.piloting
Default Belfort Instrument- Quality Products by Quality People
One of the best companies in America.
All Weather Precipitation Gauge: AEPG 600/1000
All Weather Rain Gauge
Belfort’s years of experience in precipitation measurement is behind the development of this highly accurate state of the art all weather precipitation gauge. By combining proven mechanical design with no moving parts with the latest in electronic sensor technology, the AEPG series of sensors makes it possible to measure all types of precipitation in all weather conditions without human intervention and costly maintenance. By using the latest available technology and manufacturing techniques Belfort is able to offer this latest precipitation product at a fraction of the cost of older mechanical designs.
All Environmental Operation
gsaadvantage_no_url
•-65° to +135° F (-55° to +55° C) Operation Range
•Non-stick fluoropolymer collection orifice
•Optional event controlled low power heater
•Optional Belfort wind shield
High Reliability
•3 Independent transducers provide redundant measurement (auto compensates for trasducer failure)
•On-board processor compensates for temperature and environmental anomalies
•No moving parts
•No input restrictions
•Digital RS-232 output with Programmable format
Meets Tough International Gov’t Requirements:
•High Accuracy:+/- 0.01 inches (0.25mm) or 0.1% FS
•High Resolution: +/- 0.01 inches (0.25mm)
•8″ Diameter (50 in² Area ) or 16 cm Diameter (200 cm² Area) Collection Orifice
•Precipitation Rate: 0.01 in (0.25 mm)/hr. to 120 in. (304 cm)/hr.
•Capacity:24 inches (609 mm) or 40 inches (1016 mm)
Easy to Install and Maintain
•2 inch ID ANSI Schedule 40 Steel Pipe Mount with 3 screw level adjustment
•LED Fault isolation display
•Programmable Digital output to display and monitor performance variables
The All Environment Precipitation Gauge collects precipitation though a standard 8 inch (203.2mm) NWS orifice. Precipitation falls into a bucket which is supported by three precision sensors that weigh the precipitation amount independently and transmits the weight data to a central processing unit that compares each set of data and calculates the amount of precipitation. It converts this measurement into RS-232 format output for digital transmission to a recording device of customers selection. These pulses are transmitted as binary digital signals or as contact closures of a reed relay device.
Standard Features
•Non-Stick fluoropolymer coated collection orifice
•0.001 inch resolution RS232 output
•Standard 2 inch ID ANSI Schedule 40 pipe mount
Options
•24 inch (609mm) or 40 inch (1016mm) capacity
•Heated Collection orifice (recommended for wet snow collection)
•AC or DC powered
•Single or double Belfort Alter Shield
•Wireless internet connectivity and data processing capability
•Data Output Options: •In/mm
Product Specifications
Capacity: AEPG 600 24 inch(609)/AEPG 1000 40 inch (1016mm)
Collection Area: 200 cm² (16 cm diam.) or 50.26 in² (8 inch diam., AEPG600 only)
Precipitation Rate: Range 0.01 in (0.25 mm)/hou to 120 in. (304 cm)/hour
Resolution: 0.01 in. (0.25mm)
Repeatability: +/- 0.01 in.(0.25)
Accuracy: +/- 0.01 inch (0.25mm) or 0.1% FS
Output: RS232 configurable to provide inch or metric weight equivalent amount of precipitation (optional transducer frequency output & inlet temperature)
Power Requirements: 8-18 volts DC, (3 watts nominal) Optional heaters: 115 vac, 60 cycle, 2 amps (activated by precipitation event) or 12 volts DC @ 30/60/90 watts
Operating Temperatu -65° to +135° F (-55° to +55°C)
Storage Temperatu -85° to +300° F (-65° to +150°C)
Construction: Aluminum with High Impact UV resistant thermal plastic insulating cover
Weight: n/a
The Standard Measurement
Over the years, our products have been deployed in mission critical applications, in virtually all corners of the globe and beyond. From providing wind sensors for the Wright Brothers at Kitty Hawk, to the development of mapping instruments which helped support early efforts to map the surface of the moon. We have been at the forefront of environmental measurement and are leaders in the design, manufacturing and maintenance of advanced environmental measurement systems.
DG quality? [email protected] Soaring 12 January 8th 16 11:01 PM
Posting quality Builder Home Built 6 November 23rd 09 01:07 AM
What makes a quality mic? John T Home Built 11 October 10th 05 01:04 AM
