SSA Sailplane Tracker
Old April 24th 16, 02:41 PM posted to rec.aviation.soaring
AS
Default SSA Sailplane Tracker
Is there a trick for making the life tracker on the SSA website work? I tried to follow the Perry contest but was only able to get it to work on my iPhone but not on my laptop. Only got a blank screen there. I am using Chrome as a browser and Windoze 7 Professional.
Uli
Old April 24th 16, 02:59 PM posted to rec.aviation.soaring
Craig Reinholt
Same issue here. Windows 7 Home with both Firefox or IE. Neither would work.
Old April 24th 16, 06:16 PM posted to rec.aviation.soaring
JS
Glideport.aero is working fine in Win8.1 and Win10 both with Firefox. Had to tell the home stereo (Win10) to accept the cookies, before that was blank.
Old April 25th 16, 03:27 PM posted to rec.aviation.soaring
Worked fine on my Chrome/Winduz 7 Professional
Just wished that the tracks shown were reporting altitude and fixes at 10 second intervals Some do, most don't but that is a function of the tracker not the web site!
Bob 7U
Old May 5th 16, 02:20 AM posted to rec.aviation.soaring
David Kinsell[_2_]
was blank.
I just had to confirm a security exemption to get glideport.aero to work
(Firefox on Linux). Have seen some inconsistent problems using the ssa
link.
Also, it didn't pick up my Spot trace yesterday, worked fine last year.
-Dave
Old June 26th 20, 07:18 PM posted to rec.aviation.soaring
Uli
SPOT have changed their mapping service and formats, here is how to make a URL suitable for use at glideport.aero:-
share.findmespot.com/shared/faces/viewspots.jsp?glId=09zinCBIVfVFEcsbxqddrCIFbMlqMPx xx
where the example starting with 09z is replaced by your own XML link. This has to be a separate link with a different title than your shared page. Here is how to get your XML number:-
1) log in to findmespot.com
2)Maps
3)History mode
4)Manage (little lines with check marks icon)
5)Shared Views
6) Add shared view
7) Make a shared view with a different tile such as MYXMLFeed
8) Home
9) XML Feed
10) View Details on MYXMLFeed
11) The XML Feed ID should be displayed. Copy and paste it, append it to the text
and you are good to go.
Worked for me!!
Sometimes a SPOT will work for years with glideport, then sudenly stop working. This is because if glideport ever has a communication difficulty with SPOT, it automatically deletes that particular XML feed as a safety precaution. The fix is to make another XML feed on your SPOT account, then register this new feed on glideport. There is a way to test your XML feed, simply go to this URL:-
https://api.findmespot.com/spot-main...x/message.json
with your own XML Feed ID. If you get an error message then there is something wrong with the feed, contact SPOT. If you get position fixes but glideport does not display your SPOT, then make a new XML feed and register the new feed with SPOT. Each new feed typically lasts several years, and you can delete obsolete ones on the SPOT site.
Duncan
Old September 8th 20, 09:57 PM posted to rec.aviation.soaring
John Gillis
Uli
2)Maps
3)History mode
5)Shared Views
6) Add shared view
8) Home
9) XML Feed
Worked for me!!
Duncan
Has anyone gotten the ADSB tracker link to work? I've tried adsb:myICAO but it doesn't seem to work.
Old September 20th 20, 06:11 PM posted to rec.aviation.soaring
Bruce
I've been trying to get Glideport to work with adsb:myICAO too and have had no luck with it. I've sent a message to support a few days ago and no answer yet. Since I have adsb I really think this is the way to do it. I seem to never remember to turn on my phone app. Has anyone been able to use this feature.
Bruce
Uli
2)Maps
3)History mode
5)Shared Views
6) Add shared view
8) Home
9) XML Feed
Worked for me!!
Duncan
Old September 20th 20, 06:24 PM posted to rec.aviation.soaring
Ramy[_2_]
As far as I know this feature was never implemented although the UI gives you this option.
I understand that there is currently no development and no support for glideport which is a shame since it begs integration with ADS-B and OGN.
Ramy
Old September 20th 20, 06:31 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Ramy
What is the advantage of OGN if you have a InReach or Spot Tracker thats tied into Glideport and whoever else you want to link to?
Nick
T
SSA Sailplane Tracker Nick Kennedy Soaring 2 August 17th 14 12:46 AM
GliderPort/Sailplane Tracker instructions (for contest staff)? noel.wade Soaring 1 July 1st 13 03:20 AM
Sailplane Tracker oddness/bug (15-m and Open Nats) noel.wade Soaring 10 June 27th 13 10:57 PM
SSA Sailplane Tracker problem Grider Pirate Soaring 7 April 11th 10 02:22 PM
SSA Creates National Sailplane Tracker List - Free to SSA Members Frank[_12_] Soaring 16 October 11th 09 05:42 AM
