PowerFlarm with FlarmView, I have a question.
Old May 5th 16, 07:17 PM posted to rec.aviation.soaring
Default PowerFlarm with FlarmView, I have a question.
Here at Chicago Glider Club we have the dubious distinction of flying right under the approach path into Midway airport. I have looked at SouthWest planes coming through from all angles, including head-on. Flying with a C-mode transponder helps a lot, Approach will guide the big iron around us although I'm sometimes wondering about the spacing.
My PFlarm will indicate through the FlarmView display a blue dot around my position that is blinking ONLY when a SW or bigger commercial plane (equipped with TCAS?) is coming through. Could there be a connection such that the transponder when interrogated by a TCAS responds in a way that is picked up by PFlarm? What else might the blue blinking dot mean?
Please enlighten me.
Herb, J7
Old May 5th 16, 07:50 PM posted to rec.aviation.soaring
Richard[_9_]
Herb, J7
that is a mode C or mode S transponder it is non directional and as it gets closer the circle should get smaller. Blue means it is above you.
Richard
www.craggyaero.com
Old May 6th 16, 05:32 AM posted to rec.aviation.soaring
Ramy[_2_]
It means you should zoom in to be able to tell how far the target is more or less.
Ramy
Old May 6th 16, 06:15 AM posted to rec.aviation.soaring
Darryl Ramm
Herb, J7
You've already got the answer, but a bit more detail...
TCAS is a transponder interrogator and receiver, it interrogates on 1030MHz similar to SSR radar and listens for transponder replies on 1090MHz. TCAS is all about that aircraft being able to see transponder equipped aircraft (with typical ranges of several tens of miles). That all those TCAS aircraft also have their own transponders lets them be seen by other aircraft with TCAS and your PowerFLARM's PCAS.
PowerFLARM only receives the 1090 MHz transponder replies, it cannot see the 1030 MHz interrogation signals (and they are not that interesting anyhow).. The combination of airborne TCAS interrogators and ground based SSR interrogators is what causes transponders to reply so a PCAS can see them at all. You won't see a lone TCAS equipped aircraft on your PowerFLARM via PCAS unless there is something else around to interrogate its transponder (and in your environment you have an SSR interrogator so you would see a lone TCAS equipped aircraft).
As airliners equip with ADS-B/1090ES Out heading into 2020 your PowerFLARM will see them directly via that and suppress the PCAS alert. And that happens without any interrogators being needed.
In this environment it is good to see you have a transponder in your glider, hopefully all the gliders in your club do. TCAS can't see your glider, or issue a TA or RA without that. ATC likely can't see gliders at all that are not equipped with transponders, not even as primary radar targets. Visiting FAA folks at the Chicago TRACON or the airport tower and talking with them may be a great thing to do, and maybe you folks already have done that.
Old May 7th 16, 03:07 PM posted to rec.aviation.soaring
David Kinsell[_2_]
mean?
Herb, J7
Richard www.craggyaero.com
I've been bench testing 6.06 firmware, and see what I believe Herb is
seeing. A small flashing dot right at current position, but it's short
lived and never gets bigger. It's like the range for mode c/mode s
targets is terrible. I see lots of ADS-B targets at distances greater
than 12 miles, but hardly any mode c/mode s. Maybe they gave up trying
to estimate distance for those targets?
Old May 7th 16, 05:53 PM posted to rec.aviation.soaring
I fly near a busy airport (KPRC) with several flight schools and lots of targets for my PF with butterfly rectangle display. I get alot of both Adsb and mode c/s targets the mode c consistently show up as rings and seem to jump from 6 miles to 3 miles then 2 and then 1 with a small altitude display above or below to nearest 100' seems pretty straight forward and I don't see any reason to change displays. I also like the dedicated and front and center of where I located the butterfly right on the front lip of my glare shield. Only disadvantage for me is the volume of the alerts could be louder, but I am getting hard of hearing now too
Old May 7th 16, 06:13 PM posted to rec.aviation.soaring
Darryl Ramm
And what are your PowerFLARM's PCAS range and altitude settings set to?
mean?
Herb, J7
Old May 7th 16, 07:41 PM posted to rec.aviation.soaring
David Kinsell[_2_]
Currently using the default flarmcfg.txt file, so 7000 and 600.
the spacing. My PFlarm will indicate through the FlarmView display a
Herb, J7
you.
Old May 7th 16, 08:07 PM posted to rec.aviation.soaring
Darryl Ramm
So do you have much traffic below ~2,000' AGL where you are? That are also in SSR interrogator coverage? (although TCAS should fill in as an interrogator). Why not try setting everything unlimited and see what happens.
Partial obstructions, local reflections etc. can severely screw with PCAS's estimation of range. Testing that on the ground may be a waste of time.
Herb, J7
you.
Old May 8th 16, 05:05 AM posted to rec.aviation.soaring
David Kinsell[_2_]
There's some low level traffic around, from local airports. It's
frequently interrogated, I have a separate ADS-B receiver that also shows
mode s targets, and it shows a lot of stuff buzzing around during the
day. Increasing the altitude limits of course adds more. PCAS target
range can only be increased to 10K meters, so that's a limiting factor in
how much you'll ever see with PF.
Doing more experiments, looks like the defaults aren't good at all for
the FlarmViews that Herb and I are using. In particular the protocol for
the RJ45 and d-sub gets set to 'default', much better results with
version 7. From their description, they ought to default to ver 4.
ADS-B vertical range is set for unlimited, a bizarre choice if you're
actually flying. "Process Mode C Targets" is shut off by default.
Not sure how Herb has his configured, but after setting the protocol to
7, I saw an ADS-B target show up with a plane symbol and a flashing ring,
and got the flashing blue dot when the target was right overhead. So it
seems to be a collision alert. A PCAS target showed up as just a
flashing ring, so it's working as expected now. Max range was about 6
miles in both cases.
These results were with latest firmware on PF and FlarmView, ymmv.
-Dave
happens.
time.
to?
wondering about the spacing. My PFlarm will indicate through the
Herb, J7
above you.
is seeing. A small flashing dot right at current position, but it's
short lived and never gets bigger. It's like the range for mode
c/mode s targets is terrible. I see lots of ADS-B targets at
distances greater than 12 miles, but hardly any mode c/mode s.
Maybe they gave up trying to estimate distance for those targets?
Flarmview and Powerflarm Core Config File? Papa3[_2_] Soaring 4 May 18th 15 10:51 PM
Borgelt B50 and PowerFLARM Question Paul Remde Soaring 5 May 13th 15 08:48 PM
Question about PowerFlarm IGC recording rate SoaringXCellence Soaring 5 June 6th 13 11:51 PM
Stupid PowerFLARM Question Peter von Tresckow Soaring 9 March 1st 12 11:50 AM
PowerFLARM Mode S question kirk.stant Soaring 54 October 26th 10 02:51 PM
