Interruption in Flight Log
Old May 21st 16, 08:10 PM posted to rec.aviation.soaring
Default Interruption in Flight Log
The log on my flight yesterday 05/20/16) is broken into two files as posted on OLC- can anyone help me stitch them together? Validation issue as well on one which may be due to this.
Thanks!
Gary Osoba
wosoba at cox dot.net
Old May 21st 16, 08:33 PM posted to rec.aviation.soaring
Ron Gleason
Thanks!
Gary Osoba
You can do this yourself. Use a simple text editor such as NOTEPAD and open the second file. Find the beginning of the B records, copy all of them. Open up the first file and paste the B records after the last B records in the first file. Save under another file name. Security will be no god but ...
I will be willing to assist but will take a day or so as I finish up other stuff
Ron Gleason
Old May 21st 16, 09:54 PM posted to rec.aviation.soaring
Primary recorder was a Nano which failed when it came loose from mounting.
Backup, which generated the logs posted is a Dell Streak running Tom Hat.
Gary
Old May 22nd 16, 02:30 AM posted to rec.aviation.soaring
Papa3[_2_]
Yeah... no way to get a secure log out of that. You can stitch them together as suggested above, but OLC will not score this as a valid flight. If Ron's too busy you can send them to me and I'll do it. You'll be able to analyze the flight (for example in SeeYou), but it won't pass muster for OLC, records, etc.
Erik Mann (P3)
Old May 22nd 16, 03:50 AM posted to rec.aviation.soaring
Papa3[_2_]
I read it that both loggers had incomplete files. You can't mix files from two different manufacturers.
Old May 22nd 16, 09:11 AM posted to rec.aviation.soaring
Ramy[_2_]
I believe OLC provides a form for this (and other claim issues)
http://www.onlinecontest.org/olc-2.0/gliding/help.html
Scroll to the bottom and choose option 2.5
From my experience you will normally get scored as well.
Ramy
Old June 13th 16, 04:20 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
My favorite part of Option 2.5 is the note that gets posted immediately below the "request help" box.
"Please ask somebody else with more experience (a competitor with smiley may be able to help you)"
Old June 13th 16, 07:07 PM posted to rec.aviation.soaring
Dan Marotta
I wonder if they reply to the smiley face people...
Dan, 5J
IGC Flight Recorders using Flarm firmware - New DLL file forvalidating IGC flight data files Ian Strachan Soaring 0 July 20th 14 07:28 PM
assembly interruption a dangerous thing danlj Soaring 31 May 28th 08 04:09 PM
Single Seat Aircraft: Flight Reviews and Flight Tests Robert M. Gary Piloting 1 August 17th 05 11:17 PM
FA: Vintage Textbook - FLIGHT MECHANICS - Vol 1 - Theory of Flight Paths Richard Aviation Marketplace 0 February 14th 05 01:56 PM
Does anybody know a link to a real picture of the X-43 in flight sans Pegasus or better yet a video clip of the flight? Scott Ferrin Military Aviation 0 April 3rd 04 08:47 PM
