My sailplane always turns to the left. Can I adjust the left aileron down a bit
to make it fly straight? JJ Sinclair |
First try putting the chip on the right shoulder.
On 30 Aug 2003 20:52:11 GMT, (JJ Sinclair) wrote: My sailplane always turns to the left. Can I adjust the left aileron down a bit to make it fly straight? JJ Sinclair |
It might be easier to adjust your stick hand a little to the right.
But since this is the question of the day . . . If the left turning tendency is caused by a slightly twisted wing or other rigging problem, and I assume it is, then adjusting the left aileron down a bit will not help at all. Instead both ailerons will now trail slightly down, the stick will be offset to the left, and the same twisted wing will continue to cause a left turning tendency. Instead, you would have to put a trim tab (or stick on a trim wedge) to raise the right aileron and lower the left. This assumes that the problem isn't rudder related as evidenced by the yaw string or ball being centered before this exercise. Any of these "fixes" might be used on a power plane, but wouldn't correcting the out of rig problem be the proper, low-drag fix for a glider? -- bumper "Dare to be different . . . circle in sink." to reply, the last half is right to left "JJ Sinclair" wrote in message ... My sailplane always turns to the left. Can I adjust the left aileron down a bit to make it fly straight? JJ Sinclair --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.514 / Virus Database: 312 - Release Date: 8/28/2003 |
JJ
I think the answer is NO. A turn is a coordinated maneuver. Adding a left aileron correction is an uncoordinated fix. You may be able to achieve wings level, but you will not center the T&B. It will show you flyinig in a yaw, wings level. Wings level will probably occur at only 1 trim speed. Coordinated trim fixes are needed. But the first step is to find out WHAT is causing the left hand displacement. Start with the simple stuff. Is/are all the gap seals good, wing clean etc..... Your shoes. Wear some really thin soled shoes that let you feel pressure on your feet. Something like ballet slippers. Everybody has one leg longer than the other and you might be stepping on the pedal without feeling it. After that, check rig to correct spec. If the bird checks out that way, you'll need to set up an optics shoot to find the problem. Scott Correa Ex-Wing Tooling Engineer @ Boeing. That ******** of a company that is outsourcing the future...... "JJ Sinclair" wrote in message ... My sailplane always turns to the left. Can I adjust the left aileron down a bit to make it fly straight? JJ Sinclair |
All good answers, Scott, but my real point in the question was to point out
that just moving one aileron down will not make any change in the ships tendency to turn left. Only a trim tab on the aileron (bent up) to make that ailerom fly down will accomplish the desired correction. As you pointed out, a trim tab on the rudder (bent left) would also do the same thing. Trim tabs = drag and we seldom see them on sailplanes. The real problem is usually a bad repair in the wing or bad rigging. Believe it or not, a major sailplane manufacturer has eccentric lift fittings that will correct for wing misalignment that came from the factory with twisted wings. You just tell them *how bad your ship turns left* and they determine how much *off center* your new drag fittinge should be. JJ Sinclair |
Steve wrote
Could it be possible for the flaps to have an asemetric configuration that could be causing the turn? Yes it can, Steve. A good point, even with flaps that move with the ailerons (ASW-20, etc.) The flap misalignment may cause a turn. That is to say, if the gap between the flap and aileron (on the left side) is greater than the gap (on the right side), the added drag on the left side may be the culprit. JJ Sinclair |
Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 09:32 PM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 09:40 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 12:14 AM |
