Vario installation question
Old May 28th 16, 11:34 PM posted to rec.aviation.soaring
Default Vario installation question
When installing two varios that both require a 0.45L bottle, how is this plumbed? There's lots of info online about splitting a tube from the TE probe (moving the T connector back as far as possible) but nothing on if and how two varios can share a bottle. Any help would be appreciated.
Old May 28th 16, 11:37 PM posted to rec.aviation.soaring
Matt Herron Jr.
I don't think they can share a bottle. Each would only get half the airflow and therefor not read properly
Old May 28th 16, 11:58 PM posted to rec.aviation.soaring
Dave Nadler
On Saturday, May 28, 2016 at 6:34:13 PM UTC-4, wrote:
...if and how two varios can share a bottle.
No sharing!
Old May 29th 16, 01:06 AM posted to rec.aviation.soaring
You could plumb the varios in series, but then any internal resistance impacts the response of the other vario. Not ideal, but it would function correctly.
Parallel could work, but only if you use a 0.9L flask.
If you are committed to using 2 mechanicals, then the optimum arrangement would be a T and then each vario has it's own 0.45L flask.
Old May 29th 16, 01:25 AM posted to rec.aviation.soaring
Thanks. I was wondering about the possible logic of using a 0.9L flask but I guess it is easiest to just use a second 0.45L. I have a couple of extra flasks so not a problem. And, it's not two mechanicals, it's a Winter mechanical and an LX-100 in a friend's ASW-19. We pulled out his silent Cambridge Mk IV and broken PZL.
Old May 29th 16, 08:28 AM posted to rec.aviation.soaring
You may want to consider plumbing the LX-100 with electronic compensation. That way if the TE gets damaged/obstructed you have an independent backup system.
Old May 29th 16, 05:21 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
No sharing!
Well, no sharing is best, but sharing is possible when there just isn't room without having the bottles require feet of plumbing to get to the vario. In my BS1, I have a Winter in series with my L-Nav. Knowing that internal volume of the Winter could have an impact on the reading of the L-Nav, I set my system up to be Bottle to L-Nav to Winter to TE probe. Yes, the winter acts as a bit of a gust filter on the L-Nav, but the L-Nav is still very responsive.
I guess that slowness and sharing of a bottle is why I haven't ever won a Nationals with my BS1. Oh, wait. I haven't ever taken it to a Nationals.
And, yes, Dave. I like to make you cringe with plumbing setups like this. Want to see my FLARM antenna setup? Hee hee.
Steve Leonard
Old May 30th 16, 03:02 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Of course the cool part of that statement is "my BS-1" {of 2}.
ClearNav Vario Question Dan Marotta Soaring 2 April 3rd 16 02:42 AM
Antenna installation question [email protected] Soaring 6 February 28th 08 02:14 PM
Vario loudspeaker question Greg Arnold Soaring 10 January 26th 06 10:21 PM
Another Vario question Nick Danger Soaring 3 January 2nd 06 06:29 PM
Vario Installation in PW-5 BlueGliderGuy Soaring 5 May 12th 05 12:28 PM
