2 gear up switches?
Old June 5th 16, 02:28 PM posted to rec.aviation.soaring
HGXC[_4_]
Default 2 gear up switches?
I have owned my glider for nearly 4 years and it seems that I still find new things out about it. Its a Ventus B and has a L-Nav flight computer that I use as a backup to my Oudie.
I went to test my gear up switch the other day and it didn't make any sound.. Now I always thought the gear up switch is part of my L-nav and recently I have been having some intermittent issues with my speed command graph and glide slope indicator not functioning properly.
So I start looking for broken wires and I look behind the seat and see that there are two wires that are taped to a support and i see a switch with a thin wire that has two posts not connected to anything.
Well I take the wires and attach then and voila the sound of a French police car is made when I actuate the airbrake with the gear up.
Then I read my L-NAV manual again and it never refers to any switch with a tickle wire. it takes about sensing the speed for it to actuate and the last time I flew I put the air brakes on with the gear up to test and didn't hear anything.
Could I have two alarms?
Dennis
Old June 5th 16, 04:13 PM posted to rec.aviation.soaring
JS
I went to test my gear up switch the other day and it didn't make any sound. Now I always thought the gear up switch is part of my L-nav and recently I have been having some intermittent issues with my speed command graph and glide slope indicator not functioning properly.
Dennis
Believe in later versions there is a stall alarm which is speed dependent.
Old June 5th 16, 09:23 PM posted to rec.aviation.soaring
okko kloosterman
What you describe sounds like a simple old-fashioned 2-switch system
(one at the gear lever in series with one at the airbrake lever and a
buzzer) that warns you when you actuate the airbrakes on final with the
gear up. Seems to me that it has nothing to do with your L-Nav...
Okko
Netherlands
Op 5-6-2016 om 15:28 schreef HGXC:
Dennis
Breakers as Switches - Good Idea? Six-Seven Romeo Soaring 18 February 19th 16 07:51 PM
Master Switches K Soaring 52 April 28th 13 12:11 AM
Dual Trim Switches? Christopher Brian Colohan Piloting 46 October 7th 07 08:24 PM
Gear Warning Switches on a Mosquito scooter Soaring 6 March 9th 05 01:15 PM
Fading Rocker Switches O. Sami Saydjari Owning 2 February 16th 04 03:54 PM
