Becker AR-4201 Design Fault?
Old July 9th 16, 10:01 PM posted to rec.aviation.soaring
John Carlyle
Default Becker AR-4201 Design Fault?
Has anyone else who uses a Becker AR-4201 radio experienced background noise only on 123.5 MHz?
I thought there was interference being generated in my geographic area or in my plane, but I’ve now heard noise on 123.5 in 3 different gliders using 3 different AR-4201s. A friend using a Dittel FSG71M experienced no noise at all last weekend for 3 hours when I was getting background noise, which is when I knew I had a problem.
I can raise the squelch to eliminate the noise on 123.5, but then all other frequencies have less sensitivity, so that’s not a solution.
-John, Q3
Old July 10th 16, 01:04 AM posted to rec.aviation.soaring
What other equipment are you running? I have seen the Cambridge model-20 GPS running the SN-10 generate enough noise to break squelch on just one frequency. Fix was to move antenna lead as far away from offending equipment as possible.
JJ
Old July 10th 16, 02:02 AM posted to rec.aviation.soaring
John Carlyle
Hi, JJ,
On the ground I can turn everything off except the radio and get the noise. This has been the case for all 3 gliders. The noise doesn’t sound like the usual squelch static, it’s more like a heavy diesel engine at idle but varying over a couple of hundred rpms over a 5 to 10 second period. I’ve duplicated it using a test harness in my home electronic shop. That’s why I think the source of the noise lies in the Becker AR4201 design.
-John, Q3
JJ
Old July 10th 16, 03:29 AM posted to rec.aviation.soaring
That is weird.......but I doubt it is in the radio because it only happens on 123.5. Bet you have something on that freq or a harmonic of 123.5. I remember hearing music on 123.3 in the California Central Valley, but only in certain areas. I remember flying my primitive RC model on 27 Meg's, near the base comm center. I was transmitting a series of beeps ( one beep for left, two beeps for right, when an airman came running out of the comm center shouting I was all over 243 emergency freq. I didn't believe it, so he invited me to come in and listen........ Sure enough, I was loud and clear on 243 which is the ninth harmonic of 27 Meg's)
Good luck,
JJ
Old July 10th 16, 07:28 AM posted to rec.aviation.soaring
noel.wade
John - I've seen fluorescent lights in my workshop cause static on specific frequencies. Check if turning the lights off (both in & nearby) makes the problem go away.
--Noel
Old July 11th 16, 07:51 PM posted to rec.aviation.soaring
SkyHiCO
-John, Q3
Happened to me this weekend at Moriarty.
Old July 11th 16, 09:50 PM posted to rec.aviation.soaring
I flew for several years with Becker/C302/Oudie/transponder with no radio issues. Upgraded to S80 and had significant feedback/noise on 123.5. We started placing magnets around various connecting wires/cables. The noise moved to 123.3 on one combination. With moving the magnets from the center of the connecting cables to the ends we eliminated all the radio noise/feedback.
Old July 11th 16, 11:48 PM posted to rec.aviation.soaring
I will "assume" you mean ferrites (which can kill/control outside electrical noise). They come in different sizes and shapes, "solid" or split (split makes it easier to add to existing wire runs).
An EE can comment, but I also believe they are sized/shaped depending on the frequency you're trying to kill.
Old July 12th 16, 12:11 AM posted to rec.aviation.soaring
Ferrite.
That was the word I was searching for.
They solved the problem but it took a significant amount of trials to solve the noise. The problem has stayed fixed for many months.
Old July 12th 16, 05:23 AM posted to rec.aviation.soaring
2G
On Monday, July 11, 2016 at 4:11:33 PM UTC-7, wrote:
Ferrite.
You can put a 50 ohm terminator on your antenna input to the radio and see if the noise stops. If it does you are probably receiving it from an external source. If it doesn't it MAY be generated internally, or it may be conducted from an external source thru the power leads. You can isolate that by powering the radio from a separate power source than the rest of the glider..
Tom
FS: Becker 4201 Romeozulu Soaring 0 March 7th 14 11:21 AM
Becker AR 4201 Radio For Sale Helmut Bauer Soaring 2 October 2nd 12 07:55 AM
FS: Becker AR 4201 Don[_4_] Soaring 0 September 19th 12 05:16 PM
Becker 4201 multiple failures Jean Soaring 0 August 9th 04 08:43 AM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 06:32 PM
