Dick Johnson methodology for measuring glider performance
Old July 11th 16, 02:34 PM posted to rec.aviation.soaring
Paul B[_2_]
Default Dick Johnson methodology for measuring glider performance
Hi
I have read many articles published by Dick Johnson on performance of various gliders, but I cannot find any information on the methodology he used. The closest I have come to is this from Wikipedia "Flight Test Evaluation series starting in 1976, which measured the performance of sailplanes utilizing the measurement methods taught by Dr Raspet and refined by Johnson". I am guessing that it may have been based on this article "Sailplane Performance Evaluation - Soaring May–June, 1947" by dr Raspet, but I was not able to make any further headway.
If anyone can point me to some source I would appreciate it.
Thanks
Paul
Old July 11th 16, 02:47 PM posted to rec.aviation.soaring
I thought his articles were all pretty complete.
He had an electrically powered "shaker" on the instrument panel to overcome the internal friction of the altimeter and he had a stopwatch. He flew set airspeeds and recorded the vario readings and altimeter readings while flying.
He did most of his testing in the winter on calm days when the airmass would be most stable.
I think he also had a calibrated airspeed indicator that was connected to a "bomb" that was hung out the window to compute the airspeed/pitot error.
Old July 11th 16, 04:08 PM posted to rec.aviation.soaring
Paul B[_2_]
Thanks for reply. That is the general understanding I have from reading his articles. I did not think / realised he recorded vario readings. I guess I was after more specifics, how long has he flown for a particular speed, did he need to correct for altitude, temperature etc. Did he made the calculation from altitude loss in kts, etc. Basically I am after the "method" section in his technique. I recall him writing about three tows to 10000 ft, which may point to quite long legs at a particular speed.
Cheers
Paul
Old July 11th 16, 05:07 PM posted to rec.aviation.soaring
Beyond my pay grade.
Old July 11th 16, 05:08 PM posted to rec.aviation.soaring
Ramy[_2_]
I would think nowadays performance can be measured much more accurately and easier post flight using analysis software such as SeeYou. Also I believe the true performance of the glider should use GPS altitude and not pressure altitude.
Ramy
Old July 11th 16, 05:31 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
The German Akafliegs (aeronautical groups in their universities) still do
rigourous performance measurements on gliders. You could do a lot worse
than reading their papers and/or contacting them.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old July 11th 16, 05:46 PM posted to rec.aviation.soaring
Soartech
I am curious about what pilots see on their post-flight analysis programs (like SeeYou) or in flight tools (like XCsoar) for their average L/D. Does it compare well with the advertised L/D of your ship? Or is it lower (or higher)?
For me, using XCsoar, the figure displayed is often lower than stated in my manual.
Old July 11th 16, 06:02 PM posted to rec.aviation.soaring
Matt Herron Jr.
I usually set "bugs" to 6% degradation to my official polar in SeeYou. Through trial and error, this seems to match what I actually see as performance on final glides. Glider is Ventus C with winglets
Matt
Old July 11th 16, 06:04 PM posted to rec.aviation.soaring
Depends on how good a pilot you are. I'm not happy unless I see interthermal L/D numbers over 60 due to flying energy lines, often much higher than that, if possible negative (gaining alt.). Best polar L/D is meaningless, we never fly straight at that speed.
Old July 12th 16, 01:22 AM posted to rec.aviation.soaring
Ramy[_2_]
Unless you fly in completely stable air, the post flight analysis L/D has more to do with the soaring conditions and how well you utilize energy lines, than glider performance.
Ramy
Dick Johnson Clint Soaring 4 June 6th 09 10:40 PM
Texas Glider Rally / Dick Johnson Wave Camp April 4 - 11 at Marfa Burt Compton - Marfa Soaring 2 March 27th 09 06:55 PM
Dick Johnson is gone. Burt Compton - Marfa Soaring 23 July 27th 08 05:38 PM
Dick Johnson's FTE of the Discus-2 Flavio Formosa Soaring 1 January 18th 07 03:18 PM
Contacts of Dick Johnson Francisco De Almeida Soaring 1 January 1st 06 06:07 PM
