HP-18J Twin Turbine Self-Launch Sailplane
Old July 22nd 16, 09:16 PM posted to rec.aviation.soaring
Default HP-18J Twin Turbine Self-Launch Sailplane
Here are a couple of links from my latest project. The sailplane is a Richard Schreder HP-18 kit from the 70's that I built over the last 4 to 5 years. I am using twin Jetcat P300 turbines for self-launch and sustained flight. There are numerous modifications that have been incorporated into the aircraft including the turbine installation.
First flight: https://www.youtube.com/watch?v=YepD4f9igW8 The best section is from 1:30 to 2:00 into the clip.
Colorado fly by: https://www.youtube.com/watch?v=y9BjPPhgWxo Short take of a turbine fly by from Owl Canyon Colorado in June.
Cockpit self-launch and climb out: https://www.youtube.com/watch?v=Dsc3wvxr95Y Takeoff from our local soaring field in Wisconsin using the turbines.
Restart and fly by: https://www.youtube.com/watch?v=rpgpWOG-9jI In flight turbine start and fly by.
Chris
Old July 23rd 16, 02:44 AM posted to rec.aviation.soaring
AS
Chris
Chris, thanks for sharing! Could you please post some photos of the jet installation? Inquiring minds want to know how you did it, i.e. are the jets retractable or do they stay outside?
Uli
AS
Old July 23rd 16, 06:38 AM posted to rec.aviation.soaring
Nice. what's your fuel capacity and are you running diesel?
Old July 23rd 16, 08:28 AM posted to rec.aviation.soaring
Bruce Hoult
Chris
The last video talked about retracting the engines once they cooled below 30 C (preferably 25 C). Which seems awfully cold. I can't imagine what bad would happen if they were 50 or 60.
There doesn't seem to be an excess of power. More like sustainer than self-launcher.
I was surprised how slowly the glider was flown during climb (60 knots). Effective power should be a lot higher at 80 or 90 knots (constant thrust), without a lot more airframe drag.
I was also surprised how low and slow and far out the end of downwind and base were flown, especially considering there was already flap out on downwind. And considering that HP18s can do very steep approaches. It's not an ASW12 :-)
Old July 23rd 16, 03:30 PM posted to rec.aviation.soaring
Dan Marotta
Very nicely done!
I'm interested in the FAA's take on this and will you, as the builder,
have to get a Letter of Authorization to fly it since it's a jet?
Chris
Dan, 5J
Old July 23rd 16, 03:43 PM posted to rec.aviation.soaring
Noise is usually a big problem with this type of power plant.
If the noise is exceptionally loud, we could not allow a takeoff at our gliderport.
The towplanes (Pawnee) produce a lot of noise, however, it is in a different sound level, and more acceptable. Further, the locals are used to it after 40 plus years
A turbine launch would draw more attention to towing activities and perhaps draw more attention to noise made our conventional towplanes.
Tom Knauff
Old July 23rd 16, 05:20 PM posted to rec.aviation.soaring
lynn
I timed the takeoff by watching the altimeter and it appeared to be climbing 500 to 600 fpm.
Chris
Old July 23rd 16, 07:58 PM posted to rec.aviation.soaring
Frank Whiteley
On Saturday, July 23, 2016 at 8:30:45 AM UTC-6, Dan Marotta wrote:
Very nicely done!
Chris
I was surprised how slowly the glider was flown during climb (60 knots).. Effective power should be a lot higher at 80 or 90 knots (constant thrust), without a lot more airframe drag.
Dan, 5J
I chatted with Chris while he was at Owl Canyon. This is his four project and he had to search for a good, uncompleted HP-18 kit. Nearing completion, he had to obtain a glider rating to fly it. He consulted closely with Bob Carlton during this project, indeed the engines are from Bob's jet Silent.. Chris has an interesting story to share and I hope it will appear in Soaring or Sport Aviation.
Frank Whiteley
Old July 23rd 16, 10:00 PM posted to rec.aviation.soaring
Chris
Uli
AS
Uli,
The entire build was documented on the HP Glider Forum Web site https://groups.yahoo.com/neo/groups/...bums/238228337
The turbines are retracted into the turtle deck.
Chris
Old July 23rd 16, 10:04 PM posted to rec.aviation.soaring
I started with Jet A and switched to gas station diesel. 5% turbine oil is also mixed for bearing lubrication.
The fuselage fuel cell holds just under 7 gallons. I have wing tanks that hold an additional 7 gallons which I currently am not using.
Chris
Self launch ultra-light sailplane [email protected] Soaring 6 September 27th 07 06:54 PM
Turbine Duke or turbine Baron? Montblack Piloting 1 December 13th 05 04:54 PM
Turbine Duke or turbine Baron? [email protected] Piloting 26 December 13th 05 07:50 AM
Self Launch Sailplane... Help needed with Class D operation Steve B Soaring 6 January 8th 04 08:26 AM
Electric self-launch sailplane CH Soaring 2 September 14th 03 01:49 AM
