Waterballast 101
Old July 23rd 16, 02:02 PM posted to rec.aviation.soaring
Doc[_3_]
Default Waterballast 101
A novice question for the skymasters. When ballasting my Schleicher should I completely remove the plastic cover-plate over the drain on the undersurface of the wing, or should I leave the cover attached with the tape hinge at the front and detached at the rear with cover-plate hanging down knowing that the airflow will close it in flight and then expecting the water flow to open it when dumping?
Old July 23rd 16, 03:40 PM posted to rec.aviation.soaring
The latter, leave the flap in place.
Old July 24th 16, 12:46 AM posted to rec.aviation.soaring
Doc[_3_]
Thanks!
1 glider - 11 waterballast trails John Galloway[_1_] Soaring 13 June 21st 12 10:57 PM
