Trailer surface preparation
Old July 29th 16, 09:27 AM posted to rec.aviation.soaring
Colin Roney
Default Trailer surface preparation
My plan is to remove patches of algae embedded in the GRP surface before
painting. So far, i`ve rubbed/cleaned down the surface as much as I can
using wire brush and glasspaper. Any ideas on the most effective product
to use please?
Old July 29th 16, 02:04 PM posted to rec.aviation.soaring
to use please?
West Marine sells a mildew/algae and stain remover that works.
Old July 29th 16, 10:09 PM posted to rec.aviation.soaring
Stephen Damon
Chlorine Dioxide used on AC units would probably be good if it will not harm fiberglass. ALso could use UV lights used in AC units and duct work to kill mildew, mold and bacteria.
Old July 30th 16, 02:16 AM posted to rec.aviation.soaring
Cheap easy, green Scotchbrite and a dilute mixture of water and chlorine (with some dish soap). Wash a couple of times to remove chalked Gelcoat as well as biologics.
Yes, the marine group has stuff to do similar, not sure how easy it is to find locally or the cost.
Old July 31st 16, 10:55 AM posted to rec.aviation.soaring
Colin Roney
Many thanks for the very helpful contributions.
as
well as biologics.
Old July 31st 16, 12:19 PM posted to rec.aviation.soaring
Casey[_2_]
I use "Wet and Forget" on my shingle roof, soffits, garage door, and concrete drive. Each time it rains it cleans. I've used Simple Green on aluminum camper to clean mildew and also on the rubber roof. In early '90's, the Gov bought Simple Green by the 55 gal drum. Don't use AJAX bleach alternative on fiberglass. It will dry it out. It cleans good and maybe ok if you rinse very well then paint. But I would use Simple Green.
I don't know why Cobra uses the gelcoat they do. Maybe more flexible than what boat manufactures use. But I've seen boats out in the sun twice as long as a cobra trailers and looked twice as good. Maybe glider pilots don't wax their trailers. To me, Cobra trailers look more porous than boat gelcoat and oxidize way too quick for what they cost. And I have always wondered why an Aluminum cobra trailer top is a different white than the bottom. I like Cobra trailers, but maybe because there is not much competition. But they cost way to much.
I just ran across this that looks promising: http://www.biokleen.com/hull-cleaner
I noticed you said glasspaper instead of sand paper so you are probably not in US where some of these products are available. Since you are going to paint and have used a wire brush, something harsh like the AjAX bleach alternative or something like toilet bowl cleaner or muriatic acid may work but I would rinse very well. People use toilet bowl cleaner, or hull cleaner, or muriatic acid on boats to remove stains.
Good luck.
Old August 1st 16, 09:29 PM posted to rec.aviation.soaring
Colin Roney
On the advice of a club member I finally chose a solution of ARIEL washing
powder which contains bleach and the use of a stiff brush.
concre=
aluminu=
alternat=
you=
rinse very well then paint. But I would use Simple Green. =20
than
lo=
don't=
gelc=
wonder=
bottom.
B=
http://www.biokleen.com/hull=
-cleaner
not=
to
alte=
but=
cleaner,=
Good luck.
Old August 9th 16, 01:12 AM posted to rec.aviation.soaring
Casey[_2_]
Thats probably fine for the algae and using plenty of water to rinse. I would use a self etching primer prior to painting. Then any automotive paint.
1975 trailer: https://dl.dropboxusercontent.com/u/...1/DSC00425.JPG
Old August 9th 16, 01:14 AM posted to rec.aviation.soaring
Casey[_2_]
1975 trailer: https://www.dropbox.com/sh/9icgfg36j...qIC_8cAVa?dl=0
Old August 9th 16, 11:51 PM posted to rec.aviation.soaring
Self etching primer is used for metal but I doubt it would have any useful benefit on a composite trailer.
UH
Falcon 9 1st stage tank being wrapped in preparation for shipment to the Cape 081203 installing_tarp.jpg J3 Aviation Photos 0 December 23rd 08 11:19 PM
F-1 engines being stored in the F-1 Engine Preparation Shop 6521185.jpg [email protected] Aviation Photos 0 April 9th 07 01:40 PM
pre-IFR training/preparation? Jonathan Sorger Piloting 17 February 7th 05 05:15 AM
Spangdahlem-based fighter squadron performs 3-week exercise in preparation for deployment Otis Willie Military Aviation 0 July 3rd 04 11:19 PM
Cadet interview preparation Goyan Piloting 0 May 17th 04 10:54 PM
