Low cost ADS-B Options
Old July 30th 16, 06:22 AM posted to rec.aviation.soaring
Mike Schumann[_2_]
Default Low cost ADS-B Options
I spent a day at Oshkosh last Monday and had a chance to talk to Trig about their ADS-B plans.
The Trig TT22 Mode S Transponder is currently shipping and supports 1090ES ADS-B Out, if it is connected to an approved WAAS GPS position source. Up to now, approved GPS sources have been quite expensive.
The good news is that around Christmas, Trig is going to start shipping their new, as yet unannounced, TN72 GPS position source. I had a chance to see a prototype. It easily fits in the palm of your hand, weighs about 100 grams, and uses minimal power. While Trig wouldn't commit to a price, the people I talked to said that the unit would sell for less than $600.
Couple this with an ADS-B receiver ($500 - $850), an iPhone, iPad, or Android device, and a low cost app like Foreflight, etc., and you will have a full blown collision avoidance system that will accurately display and warn you about all other ADS-B and/or Transponder equipped aircraft in your vicinity. In addition you will be visible to all TCAS equipped commercial aircraft.
Trig indicated that their distributors have significant discounts available of groups and clubs that organize a volume purchase.
This is a great solution for glider pilots who fly near metropolitan airports and are mainly concerned about collision threats with other GA or commercial aircraft.
Get your checkbooks ready.
Old July 30th 16, 11:50 AM posted to rec.aviation.soaring
Sean[_2_]
Yeah!!!!
Old July 30th 16, 01:09 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Interesting. This will be the first competition for FLARM Technology. I wonder if they will adjust their princely pricing to keep their anti-collision market share. Would this work in an area that is not within ground ADS-B coverage?
Old July 31st 16, 10:04 PM posted to rec.aviation.soaring
Darryl Ramm
I am not following what you are thinking. This is not direct competition for FLARM/PowerFLARM. This is an 1090ES Out ADS-B + source solution. It is a great thing to see happening, but it does not include any ADS-B In capability. ADS-B In solutions exist for GA but won't work at all as well as FLARM for many glider pilots, are not designed for high-traffic density glider on glider type scenarios, and won't easily fit in/integrate with most glider cockpits/avionics.
This ADS-B Out solution is great for providing visibility to ATC and GA aircraft equipped with ADS-B In (preferably 1090ES In). Another benefit of 1090ES Out carriage is it will provide longer distance visibility to PowerFLARM equipped gliders, which might appeal to some folks, like those buddy flying (PowerFLARM systems sold in the USA include 1090ES reception as standard). Maybe the best thing about this is its another sign ADS-B things are moving and that there are hopefully reasonable cost solutions coming for some clubs and FBOs that have to equip their towplanes with ADS-B Out to meed 2020 carriage mandates... and equipping them with affordable 1090ES Out is great for compatibility with gliders with powerFLARM and it's 1090ES In capability.
Old August 1st 16, 07:06 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
I have to agree with Darryl on this.
It's great see cheaper ADS-B Out GPS sources coming out to provide better position reporting to ATC and a way for gliders to light up TIS-B services and ADS-B In on other aircraft.
What's missing is a suitable commercially available dual-band ADS-B In box that receives 1090ES, UAT (if anybody is equipping with UAT), is TIS-B compatible AND puts out NMEA sentences so you can look at traffic on your Oudie, ClearNav, LX or other glider flight computer display. I'm not going to mess around in my cockpit with glide computers as well as an iPad running Foreflight.
Even if an NMEA ADS-B box were available for sale it still would only provide traffic alerts based on general proximity. I am not aware of any software currently in existence that does anything more than warn of traffic in a big hockey puck of airspace around you. None of it does collision course estimation or real collision warning to my knowledge and even if one of the GA solutions did attempt such a feat it seems unlikely that it would be optimized to not drive you up the wall with collision warnings the second you got into a thermal with another glider. Flarm does a pretty good job with both collision alarming for maneuvering gliders and filtering out nearby, but non-conflicting gliders.
I have a home-brew ADS-B receiver running a modified version of Stratux to output NMEA to my flight computer, but I think of it as a complement to Flarm, certainly not a substitute. A cheaper GPS source that works with Trig transponders will make a big difference in terms of making ADS-B In reliable since I won't have to depend on ADS-B Out from other passing aircraft to light up TIS-B traffic reporting from the ADS-B ground infrastructure, but we are still a ways from having a good ADS-B In solution for gliders - other than Flarm.
9B
Old August 1st 16, 10:02 PM posted to rec.aviation.soaring
vontresc
I was talking to the guys a uAvionix at Oshkosh this weekend, and they have a truly interesting ADS-
B solution that may actually work well for us glider folks.
http://www.uavionix.com/products/ping200b0/
They had the prototype they were testing at the show, and it truly was a tiny device. Hopebully they will follow through with the box, and get it blessed by the feds. Tiny physical size, 500mA power draw, and weighs 50 grams. Let's hope the pricetag doesn't break the bank.
Peter
Old August 2nd 16, 02:09 AM posted to rec.aviation.soaring
Darryl Ramm
On Monday, August 1, 2016 at 2:02:27 PM UTC-7, vontresc wrote:
[snip]
Peter
That is intersting, and it's great to see broad innovation happening in things related to ADS-B.
But it is worrying that the specs they present makes this not look like a Mode-S transponder. They mention no Mode-S or any other transponder related spec/standard. It might even have no 1030MHz receiver hardware at all. Once concern there in the UAV market would be the lack of compatibility with TCAS. You don't want airliners flying into UAVs, including UAVs that are out of control and have no way of avoiding the airliner. If the device is really intended to be a transponder then they have awful marketing.
The company is small and just received $5M in investment. Nothing they make meets TSO approval, but OK they are just getting started, hopefully they have folks with a background designing and manufacturing TSO approved avionics--but the company has been solidly targets the low-end UAV space. I question why they would want to worry about manned aircraft. The marketing and other costs alone just related with that for a new vendor are going to be significant. Maybe worth watching, but they need to improve their marketing/clean up/better state their claims if they think they are going after the manned aircraft market (and they certainly claim they are). They started out with a focus on receivers, which is great, but it's a very different thing to do say a TSO-ed ADS-B transmitter for general aviation.
Unfortunately reading stuff from them smells a bit too much like hype. When they talk about the PingNAV GPS source is "ADS-B Out compliant" but the needed specs are really not there, even as a promise of future compatibility. If they mean it's going to be TSO-C145c compliant or "meet the performance requirements of" then frigging say so, they have an strange way of not stating that clearly--which might be partially inexperience in the avionics market. They do clearly call out "meets requirements of" the GPS-source part of TSO-C199 (i.e. TABS). And I'm not sure it makes sense for a drone/UAV manufacturer to seek TSO approval on such a device. And TSO-C199 approval or even "meets requirements of" is not enough for ADS-B Out equipage today (certainly not in certified aircraft). Now if gliders lost their transponder/ADS-B out exemptions I'd actually like to see TABS carriage available as a means of compliance for ADS-B Out for gliders.. or available for voluntary equipage/non-mandated carriage.
BTW another interesting company in the UAV space is Sagetech (http://sagetechcorp.com/index.html). They've been shipping pretty impressive miniature transponders and ADS-B out systems for UAVs for a while. and have a less hyped feel than Uavionix.
Anyhow I guess it is good to see stuff happening. Not that I necessarily am too excited about lots of UAVs sharing airspace with manned aircraft.... but we get to sit back and see who delivers stuff here.
Old July 30th 16, 02:54 PM posted to rec.aviation.soaring
Dan Marotta
Yippee!!!
Where do I get in line? I've already got the TT22 and there's plenty of
room in the Stemme to install the TN72. Now I just have to figure out
how to mount the Nexus 7 running Avare since I've used up my two good
spots for Dell Streaks (one for me and one for Sweetie Pie). Perhaps I
can remove the Garmin 396 in the panel and install the Nexus there in a
horizontal position. I can mount the Black Berry Pi and two antennae
with Velcro... Voila! A complete system!
Dan, 5J
Old July 30th 16, 07:07 PM posted to rec.aviation.soaring
Andrzej Kobus
A word of caution. I equipped my new ASH-31 Mi with ADS-B out. I spent a lot of money to find a combination of a transponder, position source and antenna that would work in a glider. I can tell you that $3500 position source with recommended antenna would not keep the GPS lock during circling with bank angel more or equal to 40 deg. For a motor-glider there is added problem with a pylon shading the antenna, during engine run. Finding a good place for an antenna is almost impossible.
I succeeded but with lots of frustration and only because my glider is experimental.
Old July 30th 16, 07:34 PM posted to rec.aviation.soaring
Dan Marotta
Good information but I don't see much need for concern for me for the
following reasons:
Entering a thermal, I should already have a pretty good idea of local
traffic from previous glances at the display. It's not likely that
someone will penetrate my airspace during the minute or three that I'm
climbing but I do recognize the possibility and will continue to keep my
head on a swivel.
The GPS antenna will likely be mounted at the top of the instrument
panel (below the instrument cowl as the other two GPS antennae are
located). There's no engine pylon in a Stemme. ;-)
The Stratux will have its two antennae mounted on opposite sides of the
instrument cowl towards the forward edge of the canopy. There are no
obstructions above, but we'll see how that works out receiving signals
from ground stations due to the carbon fuselage.
There will always be concerns about non-ADSB-out equipped aircraft but
those numbers should dwindle as time marches on, especially in the high
western deserts.
I'm pretty excited about this.
Dan, 5J
Insurance Options? Jonathan St. Cloud Soaring 2 October 22nd 15 01:25 AM
What Options? gpick Piloting 12 September 3rd 10 01:57 AM
LED options Ken Gage Home Built 2 November 8th 07 12:01 AM
A Preliminary Assessment of the Potential Cost and Cost-Effectiveness of Space-Based Weapons. Mike[_7_] Naval Aviation 0 November 2nd 07 03:18 PM
Options [email protected] Soaring 32 March 14th 05 05:33 PM
