Good sailplanes for tall pilots?
Old September 8th 16, 12:18 AM posted to rec.aviation.soaring
Default Good sailplanes for tall pilots?
I am 6'4" tall. I weigh about 200-210lbs clothed. My height is fairly evenly distributed between legs and torso. My arms are rather long, though.
Please help me start developing a shopping list for a decent glider that I can enjoy owning and flying without cramps or impeded control movements. This would be my first foray into ownership, but I expect to own multiple in the future.
Factors to consider:
1. Prefer 2-place to single-seat, but I'm open to both.
2. If 2-place, must be FAA type-certified with standard airworthiness certificate. No experimentals. I want to be able to give commercial rides, instruction, and CAP cadet o-rides. Solo ships can be experimental, but not amateur-built.
3. Will consider self-launchers, sustainers, and motorgliders, but not looking to get into that price range.
4. Will consider antiques & open cockpits, if they have a provenance.
5. Not concerned with competition.
6. Acro would be a plus.
7. Will consider something life-limited (e.g., Lark) if I can get it super-cheap to use as a disposable platform for a couple hundred hours to better identify what I really want from a glider.
8. Priced under $30k, $10-15k is better.
My experience:
Highly active airplane pilot, IFR, 1000+ hours. Low-time glider pilot (100 hrs).
Here's what I have flown:
L-23: Fits okay, not very charming to own.
ASK-21: Tight, but doable
G103: Tighter than the ASK-21, prefer to avoid
Bergfalke: Antique wooden open-cockpit novelty; not a candidate.
I'll be trying out a SGS 1-23 and an LS-1f this weekend. There are several KA-6 models for sale all over right now (did they just get hit with an AD or something?), so some targeted opinions on these 3 would be timely.
Cheers
Old September 8th 16, 12:29 AM posted to rec.aviation.soaring
Bob Kuykendall
The HP-24 would fit you just fine, I guarantee it. It has 18m tips and FES as options. You also get to do all your own inspections and maintenance.
https://www.facebook.com/HP-24-Sailp...t-200931354951
Thanks, Bob K.
www.hpaircraft.com
Old September 8th 16, 12:56 PM posted to rec.aviation.soaring
Thanks, Bob K.
www.hpaircraft.com
The hpaircraft.com link times out with nothing loading. I don't use Facebook.
Old September 13th 16, 08:03 PM posted to rec.aviation.soaring
The website was down a couple days last week. It's up now.
Thanks, Bob K.
Old September 13th 16, 09:52 PM posted to rec.aviation.soaring
Bob Kuykendall
The website was down a couple days last week. It's up now. The latest data sheet is he
http://hpaircraft.com/hp-24/web_24_3view10.pdf
Actually, that data sheet omits the Front Electric Sustainer option that we are introducing on kit #6.
Thanks, Bob K.
Old September 8th 16, 01:22 AM posted to rec.aviation.soaring
I'm 6'1" with a long torso. I wasn't even CLOSE to fitting in the LS1-f.
I tried a discus B the other day.. Couldn't close the canopy.
I've flown and ASW-24.. but with no seat back, and no chute. Still wasn't comfortable.
I hear the HPH 304 is big. Going to try that.
I feel your pain. Just keep trying.
JP
Old September 8th 16, 02:53 AM posted to rec.aviation.soaring
Look at the Genesis 2... Very roomy cockpit. And there was one on wings fairly recently...
Old September 8th 16, 03:47 AM posted to rec.aviation.soaring
shkdriver shkdriver is offline
Member
First recorded activity by AviationBanter: Aug 2008
I'm 6'2", 220lbs, my standard cirrus fits me well with a strong 303 chute and a two inch backrest pad. Less than $20k and good factory support, I like it a lot.
Good lift,
Scott.
Old September 8th 16, 03:48 AM posted to rec.aviation.soaring
Mosquito, Jantar & Pik-20 have enormous cockpits.
I'm 6-3 and fit in the above with room to spare.
Nick.
Old September 8th 16, 04:00 AM posted to rec.aviation.soaring
rudolph stutzmann
DG 100/101 ( 1 piece canopy) or 300...
Roomy cockpit, reclined position. A friend of mine about your size fit well into his DG 100, without a chute though, and it had the 2 piece canopy...
Sooo ... Glider pilots DO make good jet pilots! AS Soaring 2 November 30th 15 09:02 AM
Good news for pilots - retirement age Greg Farris Piloting 48 January 29th 07 01:57 AM
About Good Pilots and Bad Pilots Dudley Henriques Piloting 96 February 23rd 06 01:19 AM
Are pilots really good or just lucky??? Icebound Instrument Flight Rules 68 December 9th 04 01:53 PM
Tall pilots in Helo's... BEEPER708 Rotorcraft 5 September 5th 03 05:05 AM
