Displaying ADS-B UAT Traffic on PowerFlarm
Old September 19th 16, 06:53 AM posted to rec.aviation.soaring
WaltWX[_2_]
Default Displaying ADS-B UAT Traffic on PowerFlarm
I agree with Darryl Ramm's assessment that a PowerFlarm and Mode S transponder (Trig T22 in my case) in my glider is the best solution for collision awareness and "good aviation citizenship" with other powered traffic. That's what I have in my glider.
However, monitoring ADS-B UAT (978Mhz) aircraft directly will be important once 2020 and full equipage occurs for powered traffic. Right now, PowerFlarm does a nice integration of FLARM, PCAS, and 1090ES ADS-B targets on a variety of displays. I agree with Darryl that adding a GA based device and separate non glider ADS-B situational awareness display for ADS-B is an awkward and costly solution.
Let me propose another solution...
Why not add a device that monitors just for UAT ADS-B traffic (978Mhz), and rebroadcast it at very very low power 1090Mhz in the 1090ES format for the PowerFlarm to receive, process and display? I'm not an electronics engineer or software expert, but this device could be quite small, low power and not need a user interface at all. With such a device PowerFlarm could see all ADS-B traffic on both frequencies... and would not require the FLARM people to modify any software/hardware for the U.S. market.
Any engineers ... Darryl .. or anyone else care to comment on such a device?
Walt Rogers WX
Old September 19th 16, 01:46 PM posted to rec.aviation.soaring
Alex[_6_]
That really sounds overly complex.
I would expect that any 987MHz device also has an NMEA based output to interface with Garmin instruments and other displays, as do current ADS-B and Flarm devices. If that is the case you could use a K6 MUX 2 in order to transform the output messages into a compatible format, integrate with the Flarm based data stream and send it to your displays.
Old September 19th 16, 07:16 PM posted to rec.aviation.soaring
Mike Schumann[_2_]
Walt Rogers WX
How about an even simpler solution. Have the PowerFlarm people implement ADS-R in their device. Simple software update, no new hardware required.
Old September 19th 16, 08:17 PM posted to rec.aviation.soaring
Darryl Ramm
Walt Rogers WX
Walt
Unfortunately this is not a good idea, practically or for deeper techcnial reasons.
You really don't want anything trying to transmit on 1090MHz anywhere near a ADS-B receiver. That is adding way too much complexity and potential problems.
I doubt there is a simple way to just add UAT In to a PowerFLARM, I expect it would take hardware as well a software changes within the box.
Unfortunately the USA ADS-B systems ended up such a mess that dual-link receivers are really what you want if mixing it up with GA aircraft. Certainly if buying a GA portable or fixed systems dual-link is the only receiver I would buy. ADS-B Out transmitter a whole different story, and if flying near gliders/gliderports I'd go 1090ES Out because I know PowerFLARM will see that.
How much UAT-Out vs. 1090ES Out traffic we'll see is really not clear to me.. I'm still noticing a lot more 1090ES out than UAT boing into GA aircraft, but that may be skewed at the higher end. So how important this really is I don't know. Depends on where you fly, the adoption of ADS-B out link technology, etc. The incremental add in benefit over having a transponder/ATC/TCAS/TCAD in other aircraft etc. in busy airspace is unclear. And yes I know Walt you had an unfortunate closer encounter than you wanted where that system did not help.
The best realistic technical solution would likely be for FLARM to implement ADS-R as Mike states. But that only gets you UAT traffic when within ADS-B ground station coverage, and only reliably with your aircraft has "2020 compliant" ADS-B Out. So still unclear how many glider owners that would actually help. I lose sleep worrying about the corner cases here, like a glider seeing UAT traffic via ADS-R then descending into a busy traffic pattern at an airport and all the traffic quietly disappears from the display... but is still really out there. But anyhow, until (unless?) we see mandatory ADS-B or TABS Out carriage required in gliders in the USA I'm just not too excited about PowerFLARM not supporting ADS-R, since almost nobody could use it today. And that mandatory Out equipage would certainly provide lots of capabilities (ATC and other ADS-B In equipped aircraft can see the glider, even if you can't see them. PowerFLARM would see gliders at longer distances, etc.).
That alternate solution is of a MUX box that merges UAT traffic with the Flarm dataport protocol is a non-trivial and has lots of challenges. But a benefit that it could see UAT direct without ADS-B ground infrastructure or requiring ADS-B Out in the glider. I'm not every going to hold my breath for this to happen, and I certainly am not excited about people trying to do that without a deep understanding of both FLARM and ADS-B technology. That is just not likely to go well.
The problem is the USA glider market is very small, I'm not sure how anybody justifies custom work for that size market.
Old September 19th 16, 08:29 PM posted to rec.aviation.soaring
Darryl Ramm
Just like magic. Uh no.
FLARM Dataport traffic protocol messages are a NMEA extension. But no UAT avionics manufacturer makes products that talk FLARM's dataport protocol. This needs much more than a K6 MUX, it needs something converting raw traffic data in other formats into NMEA/FLARM Dataport, combining that with a Dataport stream, deduplciatiing traffic etc. and is non-trivial. There are devices available in Europe that add 1090ES In capability to existing FLARM systems, with varying success/capabilities, there is no UAT equivalent.
Old September 20th 16, 05:10 AM posted to rec.aviation.soaring
WaltWX[_2_]
Darryl,
Thanks for the reply regarding rebroadcasting ADS-B 1090ES packets converted from UAT 978. I suspected it is complex and had hidden technical problems that I do not understand. It just seemed like not having to modify PowerFlarm hardware or software MIGHT be a solution... since the market is too small for them to worry about (U.S. only problem).
FLARM... if you are LISTENING... please indicate whether UAT ADS-B packets could be integrated into your PowerFLARM hardware/software. Perhaps a development engineer willing to work with you in the U.S. that would take this on as an Open Source project. Yes... I agree, FLARM... it's too small a market for you to attack as a product enhancement.
Walt Rogers WX
Remarkable web app displaying winds, etc. Jim Lewis[_2_] Soaring 6 January 19th 15 09:51 AM
Butterfly display (displaying a big red logo under normal flight conditions) RuudH Soaring 33 March 17th 14 04:47 PM
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 01:50 AM
Traffic 2004 vs Ultimate Traffic Tlewis95 Simulators 3 August 13th 04 05:39 AM
CBAV - anyone having problems displaying Nexrad? Maule Driver Instrument Flight Rules 29 July 21st 04 04:58 AM
