K21 trim tightening?
Old October 6th 16, 10:57 PM posted to rec.aviation.soaring
Default K21 trim tightening?
The trim in our club's K21 is no longer effective and I suspect it is probably a simple matter to tighten up a nut somewhere below the front seat so there is more friction on the trim lever.
If anyone had a moment to confirm my suspicion and had any pointers, that would be appreciated.
Mark
Old October 7th 16, 01:25 PM posted to rec.aviation.soaring
Thanks! Is it accessible through the stick boot or does the seat pan have to come out?
Old October 25th 16, 10:22 AM posted to rec.aviation.soaring
Eric Munk
There's also some usefull information in the flight manual on trim
adjustment. Is worth replacing the springs as well under the rear floor
pan. They tend to loose their pull after so many years of use. Very little
cost.
How much do you trim? Mxsmanic Piloting 89 October 13th 06 05:14 AM
Problem with trim? [email protected] Piloting 0 August 30th 06 05:27 PM
Electric Trim Jon Woellhaf Piloting 3 October 4th 05 02:31 PM
LS4 trim bagmaker Soaring 1 September 10th 05 03:00 PM
trim tab help Robert Loer Home Built 0 March 29th 04 08:30 AM
