Diana 2 FES
Old October 18th 16, 11:46 PM posted to rec.aviation.soaring
Kevin Christner
Default Diana 2 FES
Does anyone else think this would be an unbelievable combination?
Old October 18th 16, 11:55 PM posted to rec.aviation.soaring
Kevin Christner
Default Diana 2 FES
To further elaborate with its low weight it could probably self launch
Old October 19th 16, 12:46 AM posted to rec.aviation.soaring
Andrzej Kobus
Default Diana 2 FES
It already does in 13.5 m configuration, shortened wing tips and modified cone.
http://soaring.eu/wp-content/uploads...21054993_n.jpg
Old October 19th 16, 01:11 AM posted to rec.aviation.soaring
Kevin Christner
Default Diana 2 FES
Are these being produced / would it be possible with the 15m?
Old October 19th 16, 04:27 AM posted to rec.aviation.soaring
Tony[_5_]
Default Diana 2 FES
Stephanos glider, as I understand, can fly 13.5 or 15.
Old October 19th 16, 07:15 AM posted to rec.aviation.soaring
Per Carlin
Default Diana 2 FES
Why spoil Dianas performace advantage with and FES?
Old October 20th 16, 01:37 PM posted to rec.aviation.soaring
Default Diana 2 FES
for the moment at least, you need to have your own Diana2 and modify it. Alisport I think already modified two existing Dianas
Aldo Cernezzi
www.voloavela.it
Old October 20th 16, 02:11 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Diana 2 FES
Per Carlin wrote on 10/18/2016 11:15 PM:
Performance advantage over what? There are many higher performance
gliders than the Diana! ;^)
A Diana with an FES has a slightly lower gliding performance, but it's
performance by other measures is increased. It's self-retrieving
performance allows it to have good flights in marginal weather that
would have a standard Diana back on the ground in short order, and in
good weather, it let's a pilot practice fast flying more aggressively
than he would otherwise dare to.
And if it's self-launching, it's soaring performance from airports
without towplanes would be spectacularly better!
email me)
https://si
tes.google.com/site/motorgliders/publications/download-the-guide-1
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old October 20th 16, 03:13 PM posted to rec.aviation.soaring
Andrzej Kobus
Default Diana 2 FES
Not in the 15 m class.
email me)
https://si
Old October 20th 16, 04:00 PM posted to rec.aviation.soaring
Default Diana 2 FES
So I can drive 20 minutes to an airport and self launch, rather than 2+ hours to a towplane.
Also, you can always take the FES nose cap off and put on a clean one if you thought you could win a national championship. I am unlikely to be there any time soon.
F/S szd-56 Diana zxcvb Soaring 0 October 8th 10 08:39 AM
SZD-56 Diana Wayne Paul Aviation Photos 0 March 11th 08 01:19 PM
Diana-2 VH-VHZ BlueCumulus[_2_] Soaring 3 July 25th 07 08:00 AM
Odp: SZD 56-2 DIANA Yurek Soaring 4 January 31st 05 08:46 PM
SZD-56-2 Diana Yurek Soaring 1 January 29th 05 01:02 PM
