Towing X2 - Possible? Dangerous? Illegal?
Old October 20th 16, 02:04 PM posted to rec.aviation.soaring
OHM Ω
Default Towing X2 - Possible? Dangerous? Illegal?
A friend of mine (seriously) is about to retire and wants to begin touring the US with an RV while towing a glider trailer. Been done many times. No issues to speak of with this concept.
But he also does NOT want to use the RV to tow the assembled glider around the airport during events. He would much rather bring another smaller vehicle along for the tour for the "tow out".
His current idea is using a three-wheeler motorcycle. It would be on a ramped flat bed suspended from the back of the RV and then the glider trailer behind that. You can see some of those ideas here http://www.mightyhauler.com/ (with a car instead of a glider). Anyone done this? So that is idea number one.
But a car might be better than a motorcycle (for events and for side trips) so is there an option for that? It might be a hair-brained idea but could an RV haul a ramped car trailer and add a glider trailer behind that? Obviously, you cannot back up but is it too long? Too dangerous? Too illegal?
Expiring minds want to know.
Thanks, John OHM
Old October 20th 16, 02:35 PM posted to rec.aviation.soaring
Bruce Hoult
Why can't you back up? It's only a matter of skill :-)
The most evil thing I've reversed with on a regular basis is the Bamford hay rake, which is a trailer with the hitch attached to a steering front wheel via a pretty short tongue. But we do it :-)
http://images2.hellotrade.com/data3/...ke-500x500.jpg
I have no idea about the legality.
If you can arrange for the glider trailer to hitch onto the car trailer right above the axle (i.e. have the axle at the back, not in the middle) then you might well end up with something both more stable to tow and easier on the glider than attaching it directly to the RV.
If you use a tray for a trike/quad then you'd want to extend the glider trailer tongue to still attach to the regular hitch, not to the back of the tray.
Old October 20th 16, 03:07 PM posted to rec.aviation.soaring
Dan Marotta
It's too long in New Mexico and Colorado. I researched it. Thankfully I
never tried it since losing the car would also result in losing the
glider. Better to simply rent a car while at the event.
Thanks, John OHM
Dan, 5J
Old October 20th 16, 03:27 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
A friend just bought an RV with a "toy box" in the back end. He has a three wheel Morgan on its way that he will haul around in there, park, open the back door, and drive the Morgan out. It will be his "get around" vehicle once he gets where he wants to stay for a while. Or, for any stop where he decides he wants to do a little "cruising around" without doing it in a big, clumsy for close quarters RV.
And with this setup, the other vehicle is stored indoors while on the road (basically, the back 10 or so feet of the motorhome is the garage).
Steve Leonard
Old October 20th 16, 05:17 PM posted to rec.aviation.soaring
I have a 34 foot class A that I tow my Glider with. I also tow a toad 4 wheel down cavalier when I don't have the glider. The problem I have is the weight I could put on the rear axle is limited to about 200 lbs. So I custom built a rack for the front where I had 600 lbs to use and mounted a Honda Rebel 250 motorcycle. Most States have max vehicle length combined at 65 feet and you can't have more than one thing in tow unless the first vehicle is a fifth wheel configuration to which you can add a trailer. The real issue then becomes total length. Also I thought of a "Stacker" trailer for both a Car and glider trailer, but they are expensive as well. I don't ground tow the glider with the motorcycle at flying sites but probably could if very careful and slow. There are usually friends with other vehicles to borrow and in case of the occasional land out I can use the Motorhome to retrieve.
Old October 20th 16, 05:23 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Why not get a fifth wheel set up, with the trailer with the entire back acts as a ramp. The guy that go tear up the desert use these, they have living space and space for the toys inside.
Old October 20th 16, 06:47 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Steve Leonard
I think he got one of the Class A of this type.
https://thormotorcoach.com/outlaw/
Should be able to pull your glider behind, and have your run-about with you inside in the "toybox" at the back end. You don't need two trailers...
Old October 21st 16, 02:47 PM posted to rec.aviation.soaring
Don Grillo[_2_]
As Steve mentioned, one thought is to purchase the Thor Outlaw 37RB (link below) that has a 10ft garage in the rear and was made to accommodate a Smart Car. A class one trailer hitch is available for the Smart Car which carries a max load of about 200# on the tongue and about 1100# towing capacity. That would work out fine for a tow out vehicle and would also be able to use the car for site seeing etc. It will not and would not be safe to tow the glider trailer with the Smart Car (maybe just around the airport grounds) so landing out still requires the use of the RV or a borrowed car/truck. That would require the RV to be on the airport grounds. But what if RV parking is not allowed on the airport? The RV then needs to be at an RV park, possibly a long distance from the airport, which then requires the RV to be unhooked from power/water/sewer everyday and brought out to the airport daily.. Kind of a pain.
More thoughts to follow.
Don
F2
Steve Leonard
Old October 21st 16, 03:22 PM posted to rec.aviation.soaring
Don Grillo[_2_]
Another Thought:
Purchase a 30+ foot RV, install a HydraLift capable of carrying a trike or Can-Am Spyder (3 wheeler) on the back of the RV. Put a hitch on the 3 wheeler for a tow out vehicle. The hydralift also allows for towing a vehicle or trailer.
http://hydralift-usa.com/canam-spyder/
Old October 20th 16, 08:44 PM posted to rec.aviation.soaring
JS
Talk to the Willats.
They used a pickup and toy hauler with two gliders (Nimbus 3 and Discus) and one trailer inside.
Most Dangerous Time? Ol Shy & Bashful Piloting 18 October 5th 08 10:11 PM
How dangerous is soaring? [email protected] Soaring 102 November 6th 07 03:33 PM
Okay, so maybe flying *is* dangerous... Jay Honeck Piloting 51 August 31st 05 03:02 AM
Dangerous Stuff [email protected] Rotorcraft 21 July 16th 05 05:55 PM
40,000 U$ Soldiers are Illegal Aliens, Drafted for Illegal War Gordon Military Aviation 6 September 7th 03 03:28 AM
