gear up warning trip switch
Old October 20th 16, 05:48 PM posted to rec.aviation.soaring
HGXC[_4_]
Default gear up warning trip switch
I broke the gear up warning trip switch on my glider. It was positioned near the landing gear mechanism and had a wire that actuated a warning sound.
Des anyone know a source for a replacement?
Dennis DC
Old October 20th 16, 06:22 PM posted to rec.aviation.soaring
Vernon Brown
sound.
Dennis DC
You didn’t say what type of switch was been use, I presume it is a micro
switch, so contact has to be made to actuate it, why not use a reed switch,
actuate by a small magnet in close proximity, no need to physically make
contact.
http://uk.rs-online.com/web/p/reed-switches/5309009/
Old October 20th 16, 07:13 PM posted to rec.aviation.soaring
Craig Funston
Dennis DC
Mouser http://www.mouser.com/Search/Refine....rd=microswitch
or
Digikey http://www.digikey.com/product-searc...&newproducts=1
There's also a ton of them in things like retired (junked) copiers and other electronic equipment.
Cheers,
7Q
Old October 20th 16, 08:25 PM posted to rec.aviation.soaring
Vernon Brown
sound.
Dennis DC
or
Digikey
Cheers,
7Q
The idea is to avoid micro switches, I have had a lever fall off one in
flight, so had to fly with the wheel down for the rest of the flight to
stop the rackets from the buzzer, so use a reed switch, no physical contact
is needed, when the magnet is moved close to the reed it operate, the reed
could replace your micro switch, and the magnet where the actuator was.
Old October 20th 16, 11:06 PM posted to rec.aviation.soaring
bumper[_4_]
If you use a magnetic reed switch, there's some more things to consider.
First you'll need to determine if the gear warning sounds when the switch is open, or closed. Both types of switch are available, with magnet present a switch may be closed (the most common type of reed switch) or it may be open with the magnet present (there being a tiny biasing magnet within the switch that closes the reed when the external magnet is moved away.
Then there are "wide gap" reed switches too. These are magnet polarity sensitive, so the external magnet needs to be positioned so the correct pole approaches the switch (these switches will still operate if the external magnet is positioned incorrectly - they will just revert to a very small gap).
If the magnet is to be mounted on steel (as in tubing etc.) then better performance will be had if the magnet is not mounted directly to the steel.
Old October 21st 16, 01:48 AM posted to rec.aviation.soaring
HGXC[_4_]
Dennis DC
My current set up is for a micro. I was just going to duplicate what was there. I'm not sure how to set up the reed?
Dennis DC
Old October 21st 16, 04:25 PM posted to rec.aviation.soaring
Dan Marotta
I have a complete system, never installed, that I picked up somewhere
back in the early 90s. It includes two micro switches, a battery
connector for a 9-v radio battery, a piezo horn, and an ON/OFF switch.
It's all wired together, but can be taken apart to use a switch in your
own installation. Frankly, I'd wire it into ship's power without a
switch. Just one more thing to forget.
Send me your address and I'll send it to you for free (assuming I can
locate it, I think I know where it is). I'll need postage if you're not
in the US.
Dan
Dennis DC
Dennis DC
Dan, 5J
Old October 21st 16, 08:34 PM posted to rec.aviation.soaring
I have a switch - took the battery out of it a long time ago.
I have a butterfly hair clip - I put it on the release knob (actually a string) - when I release I pull up the grear and I move it to the spoiler handle - when I am landing I lower the gear and move it back to the release knob
Works GREAT!
WH
Old October 21st 16, 10:39 PM posted to rec.aviation.soaring
Dan Marotta
Default gear up warning trip switch - Retracting My Offer
Sorry, I've scoured my hangar and can not find the switches I offered to
give away. I must have given them away to the person who bought my last
glider.
Dan
switch. It's all wired together, but can be taken apart to use a
switch in your own installation. Frankly, I'd wire it into ship's
power without a switch. Just one more thing to forget.
not in the US.
Dan
Dennis DC
Dennis DC
Dan, 5J
Old October 22nd 16, 12:36 AM posted to rec.aviation.soaring
HGXC[_4_]
glider.
Dan
not in the US.
Dan
Dennis DC
Dennis DC
Dan, 5J
Thank you Dan, that is a very generous gesture and I truly appreciate it. I have a L-nav as one of my flight computers and as I understand my manual it also can be used as a gear up warning but. I don;t understand how to use it. I also have thought about the opportunity for the switch failing and having to fly with gear down.
Since my knowledge of how the wiring is weak I choose to just replace the existing switch.
Thanks again Dan,
Dennis
ASW-20C Gear Warning Switch Placement Jim Kellett Soaring 3 May 16th 09 01:20 AM
Stall warning switch for Cessna 206? [email protected] Owning 1 February 20th 07 09:16 PM
Gear Warning Gadget Guy Soaring 118 November 30th 05 10:43 PM
Gear Warning Gordon Schubert Soaring 11 November 22nd 05 03:27 AM
gear warning plus K.P. Termaat Soaring 0 September 8th 03 08:33 AM
