Altitude gain: qualitative analysis
Old September 29th 03, 01:10 PM
Chris OCallaghan
Default Altitude gain: qualitative analysis
Flew on Sunday in non-stable conditions. David Pixton flew his Ventus
2b at approx. 800 lbs, and I flew my Ventus 2bx at 1150 lbs. Because
conditions were turbulent, we were unable to do any smooth air
testing, but during the course of 10 pull ups (entry 100 knots, exit
60 knots) we observed the following:
Wing abreast with about 100 to 150 feet of separation, pull ups were
either even or slightly better (10 to 20 feet) for the heavier glider.
Because we were following a cloud street, we were unsure whether the
apparent parity was actual or lift related. Dave was selecting the
path, so it is possible that he was better centered in the lift
street.
I repositioned directly behind Dave (less than 100 feet). With each
pull I was forced to maneuver to avoid him, and would generally gain
between 10 to 30 feet. On one pull however, I gained more than 50
additional feet. In each case, I was forced to deploy spoilers to get
back into position for the next pull. It appeared that the stronger
the core we pulled in, the more advantage I got. On a few occasions,
Dave pulled to less than 60 knots, and while this cut down on my
advantage, I regained it immediately (and then some) as we returned to
cruising speed.
It is interesting to note that during these tailored pull ups and
during subsequent street running with freeform pulls, Dave never
gained on me. I found myself making S turns to keep from overtaking
him. When at last I took the lead, the overall advantage to the
heavier glider was apparent and substantial.
We'll try this again in still air, but initial results indicate that
there is a marked difference in climb during each pull up. Even at a
conservative 15 feet per pull, a hundered such pulls during a task
would account for 1500 extra feet, and this doesn't include the
advantages water offers during the cruising phase of flight.
So to answer the question, "is there a difference?" the answer is
yes... in theory and in practice. Dave commented after the flight, "I
need to get back into the habit of putting water in the wings."
If I can muster Dave for some early moring flying, we'll get some more
quantitative results.
OC
Old September 29th 03, 03:59 PM
Scott Correa
"Chris OCallaghan" wrote in message
om...
street.
cruising speed.
OC
Thanks for taking the time to do this....
Scott.
Old September 29th 03, 05:24 PM
Andy Blackburn
Thanks for adding real, empirical data to the discussion
Chris.
I think 20-50 feet is less difference than a lot of
us would intuitively have thought initially, but pretty
close to where the analysis has led us collectively
(e.g. no difference in a kinetic energy-to-potential
energy sense, a small difference [15-20 feet] in favor
of the heavier glider due to differences in the unaccelerated
[1G] polar, and an indeterminate difference due to
the G-load losses from the pullup).
Don't forget that in a series of pullups over time,
the heavier glider should steadily gain on the lighter
one just due to the middle effect (i.e. the difference
in L/D at the same speed).
Nice job in getting real data!
9B
flew his Ventus
1150 lbs. Because
smooth air
100 knots, exit
pull ups were
the heavier glider.
whether the
selecting the
in the lift
street.
feet). With each
generally gain
more than 50
spoilers to get
the stronger
a few occasions,
down on my
as we returned to
cruising speed.
pull ups and
Dave never
from overtaking
to the
indicate that
up. Even at a
during a task
include the
flight.
So to answer the question, 'is there a difference?'
the answer is
the flight, 'I
the wings.'
we'll get some more
OC
Old September 29th 03, 10:03 PM
Mike Borgelt
On 29 Sep 2003 05:10:39 -0700, (Chris
street.
cruising speed.
OC
Here's what I posted earlier in this topic:
Let's define the problem a little better - a pull up from 100KIAS to
50 KIAS, level flight in both cases.
Pull to a flight trajectory of 30 degrees up relative to the horizon.
This gives a vertical velocity of 50 knots immediately after the
pullup. That 50 knots requires an extra 1 g for about about 2.5
seconds(some simplification and approximation here)or a suitable other
combination of G load and time). At the high speed the extra induced
drag is quite small for a short time so can be neglected to a first
approximation. The pullup will take only a few seconds,10 so that
difference in height gain is the difference in ballasted and
unballasted sink rates for a few seconds. At the low end the sink rate
difference is very small and at the high end the ballasted glider has
lower sink rate. This difference might be as high as 200 feet/min but
we are only talking for a small fraction of a minute so we get maybe
30 feet difference in favour of the heavy glider, maybe only 10 to 15
feet.
Please note in the kinetic/potential energy equation the mass cancels
out so to a really rough first approximation neglecting the effect of
ballast on the polar the height gain is the same.
It's nice when the experimental results match the theory.
Note that all you are seeing in your flight test is the difference
between the polars of two nearly identical gliders with different
ballast loads at high speeds. (faster than best L/D)
The pull up/pushover manoevering is largely irrelevant.
Mike Borgelt
Old September 29th 03, 11:42 PM
Denis Flament
So... a heavy glider has a better L/D ratio - what a news ;-) !!!
what you have to find out is whether the advantage in the pull-up is the
same - or higher, or lower - than the advantage the heavier glider has
at cruise speed...
Denis
Private replies: remove "moncourrielest" from my e-mail address
Pour me répondre utiliser l'adresse courriel figurant après
moncourrielest" dans mon adresse courriel...
Old September 30th 03, 06:24 AM
Andy Blackburn
Let's hear it for math! ('maths' for some of you outside
the US).
9B
from 100KIAS to
to the horizon.
after the
about 2.5
a suitable other
the extra induced
to a first
so that
and
end the sink rate
glider has
200 feet/min but
so we get maybe
only 10 to 15
feet.
the mass cancels
the effect of
the difference
with different
Mike Borgelt
Old September 30th 03, 10:42 PM
szd41a
Thank you for the tests.At last somebody get ou there and do the real
thing!!!Very interesting!!!and quite surprising for me, thinking this would
be a tie. Now for the rest of us, we will have to check our maths!!!, may I
ask what was the average gain from 100 to 60 knts ??
Again thanks a lot, and we hope to see some results in still air.
BQ
"Chris OCallaghan" a écrit dans le message de
om...
street.
cruising speed.
OC
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
GPS Altitude with WAAS Phil Verghese Piloting 38 October 5th 03 12:39 AM
