Weight/balance question
Old June 8th 04, 02:16 PM
Bob Martin
Default Weight/balance question
Is a statement such as the following acceptable for weight and balance
calculations for flying?
"As long as the maximum baggage weight of XX lbs and gross weight of
xxxx lbs is not exceeded, the aircraft will be in balance"
Old June 8th 04, 04:36 PM
Jan Carlsson
Aeronca too, but don't use that on all aircrafts! :-)
Jan Carlsson
www.jcpropellerdesign.com
"Carl Ellis" skrev i meddelandet
. 97.136...
Ron Wanttaja wrote in
Taylorcraft too.
- Carl -
Old June 16th 04, 03:11 PM
Wright1902Glider
Hmmm... would I be correct in assuming that on aircraft placarded this way, it
would be physically improbable to load baggage in an area of the airframe that
would cause an out-of-limit CG issue if the weight limit was not exceeded?
Just wondering... CG is a VERY big issue with pioneer-era airframes, and
simply leaning back could/did cause stalls 100 years ago.
Harry
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Question for Squirrel the Lurker jls Home Built 0 January 30th 04 02:41 PM
Poly Dope Question Michael Home Built 3 January 29th 04 07:10 AM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
