Birds in the hangar
Old November 4th 16, 01:43 AM posted to rec.aviation.soaring
Ben Coleman
Default Birds in the hangar
Our club is discussing what we can do to deter birds from perching in our hangar and messing up our aircraft. Can anyone recommend a technique? Are there any methods which have not worked?
The birds are small, probably swallows.
Thanks Ben
Old November 4th 16, 07:08 AM posted to rec.aviation.soaring
Can the hangar be effectively sealed? By which I mean are the doors tight fitting enough that closing them, sealing cracks and putting grilles on vents etc. make it pretty much impossible for birds to get in and out? That was what worked well for someone I know who has a hangar and had this problem. Swallows might respond well to properly designed birdhouses on the field as a way to keep them out of the hangar too. Swallows eat a lot of insects and are fun to watch flying around so if you can figure out a way that keeps them in the area but not crapping on the gliders it's well worth some effort.
Old November 4th 16, 09:29 AM posted to rec.aviation.soaring
Ben Coleman
Probably not for our main hanger. It is roughly 25x25m (or more) and holds around 13 gliders. Of course anything can be done but probably looking for something less daunting.
Regards Ben
Old November 4th 16, 10:09 AM posted to rec.aviation.soaring
Surge
Regards Ben
How effective are those rotating reflective prisms that one can see mounted on the top of buildings?
Example: http://www.birdbarrier.com/content/2...ered-versions/
Old November 4th 16, 10:15 AM posted to rec.aviation.soaring
We have an electronic deterrent that makes a high frequency sound the birds don't like. All people can hear is an intermittent clicking noise. It seems to work, the birds hardly crap on our lawnmowers at all! (We tie down our all metal fleet.)
Google: Bird-x qb4 electronic bird repeller.
Old November 4th 16, 10:38 AM posted to rec.aviation.soaring
AS
Thanks Ben
The birds (pigeons) in our hangar died suddenly from high velocity lead poisoning.
Uli
Old November 4th 16, 01:12 PM posted to rec.aviation.soaring
Thanks Ben
You might try keeping a light on in the hangar.
I put a LED floog light in the hangar and left it on 27/7 and the birds have not returned.
bob
Old November 4th 16, 01:26 PM posted to rec.aviation.soaring
glidergreg
Thanks Ben
We have used the Bird X QuadBlaster QB-4 for over a decade, works very well keeping birds out of the hanger, Emits a very high pitch series of sound pulses that most people can not hear, some younger people can detect it and find it annoying. This devise is not cheap around $550.00. we have it mounted on a side wall of a 60 x 60 hanger. Installed a on off wall switch to shut it down when necessary. Web site URL http://www.bird-x.com/quadblaster-qb...hp?page_id=103
Old November 4th 16, 01:36 PM posted to rec.aviation.soaring
Dave Nadler
Oddly, the roof started leaking just afterwards...
Old November 4th 16, 02:29 PM posted to rec.aviation.soaring
Vaughn Simon[_2_]
Actually, farmers solved that problem many decades ago. Just use the
correct ammo.
http://www.basspro.com/Federal-GameS...0829053330614/
Two Birds Avsec Aviation Photos 2 January 29th 08 01:19 PM
Birds, Birds, Birds! Kyle Boatright Piloting 4 October 30th 07 04:04 PM
Are birds IFR? Kevin Clarke Instrument Flight Rules 28 September 30th 06 08:57 PM
The BIRDS Kyle Boatright Piloting 29 March 5th 06 11:50 AM
Fat Birds Bob Chilcoat Piloting 14 January 29th 06 01:27 PM
