Oudie2 to borrow or rent for Australia
Old November 9th 16, 06:09 PM posted to rec.aviation.soaring
Sean[_2_]
Default Oudie2 to borrow or rent for Australia
All,
I am looking to borrow or rent an Oudie2 for my upcoming trip to Australia. I leave in a couple weeks and return in late January. The Oudie2 that I was planning on just fell through. My friend secured a glider to borrow in Florida this winter and needs it. So, I am now looking for another. As the Oudie is not my favorite, I'm trying to avoid owning one again. The only reason I will have it in my glider is for the team code function.
Thanks for considering.
Sincerely,
Sean
7T
Old November 10th 16, 12:02 AM
Josh Fletcher Josh Fletcher is offline
Junior Member
First recorded activity by AviationBanter: May 2013
Sean,
I have one you can borrow. However you will probably need to update it. All I have with me is the Oudie2 and USB cable for it.
Just let me know if you want to use it.
Josh
Old November 10th 16, 03:09 AM posted to rec.aviation.soaring
Sean[_2_]
Josh,
Wow. Thanks!!!! Very much.
Ill reach out now.
Old November 9th 16, 08:32 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I would also suggest you rent, borrow or purchase a foam cover for your boom mike, the duct taped foam from packing crate sends the wrong message to competitors. Good Luck, fly safe
On Wednesday, November 9, 2016 at 10:09:48 AM UTC-8, Sean wrote:
All,
Sincerely,
Sean
7T
Old November 10th 16, 03:08 AM posted to rec.aviation.soaring
Sean[_2_]
Jon St. Cloud,
Ha Ha. I actually have fixed that.
Old November 10th 16, 12:15 AM posted to rec.aviation.soaring
Dave Nadler
Hi Sean - You can find one he
https://groups.google.com/d/msg/rec....4/eZy6sL5RBwAJ
PW-5 Panel-Need to buy, lease, or borrow [email protected] Soaring 0 October 25th 12 01:48 PM
Need to borrow/rent EDS O2 system for SC Nats in Parowan Frank[_12_] Soaring 7 January 23rd 10 05:23 PM
Borrow or buy a 1550 bracket Dick[_3_] Soaring 1 February 20th 08 06:27 PM
PW5 Wanted to Borrow Kevin Christner Soaring 0 December 12th 03 01:37 AM
need to rent(borrow?) 1-2 life vests (a raft?) for Oshkosh Vassilii Khachaturov Piloting 9 July 15th 03 03:41 AM
