Let's Hear It From Homebuilders Who Make Your Own Sunshields and Panel Glareshields
Old June 9th 04, 07:56 PM
jls
Default Let's Hear It From Homebuilders Who Make Your Own Sunshields and Panel Glareshields
I'm trying my hand at it now. Sun shields will probably fit inside the
plexi windows and be something stiff like that honeycomb signboard cut to
shape and covered with aluminum foil and then maybe a film of cellophane or
clingwrap to keep from scratching the soft plexiglas windows.
For the glareshield over the panel, I'm making a pattern from cereal box
cardboard, then cutting 016 aluminum to fit, then covering it with 1/2"
thick foam and then maybe leather or naugahyde, or whatever. How about
some ideas here. And thank you for your support.
Nice article about sunshields at Avweb, interview with Kennon on how they do
theirs and what they recommend and why.
Old June 10th 04, 03:04 AM
On Wed, 9 Jun 2004 14:56:28 -0400, " jls"
I would recommend using something other than aluminum for the
glaresheild unless the aluminum is rivited very well to the instrument
panel, and has the edge rolled. A sharp sheet of aluminum is like a
knife if it ever gets forced back into the cockpit...
Putting a slight curvature in the panel to make it deform upwards
rather than trying to come back would also help.
Old June 10th 04, 04:44 AM
Ed Wischmeyer
thick foam
Choose your foam carefully so that it doesn't give off toxic fumes or catch
fire in case you're slow getting out after an accident.
Good luck!
Ed Wischmeyer
Old June 12th 04, 07:08 AM
Roger Halstead
Strange you should mention that. I remember seeing a glare shield made
of 1/8th inch plywood and covered with naugahyde. It had the neatest
set of teeth prints on each side...
I'd not rivet the glare shield to the panel though. Screwed down? you
bet, but not riveted. You might have to fix something in there one
day.
Myself? I think I'd use a sandwich made of foam and extremely thin
aluminum bonded and covered with leather or naugahyde. Something with
"crushability", but not only strong enough to hold its shape, but a
heavy mug of coffee, or wrenches, or....
www.rogerhalstead.com
Old June 12th 04, 04:12 PM
Tim Ward
"Roger Halstead" wrote in message
to
or
they do
day.
How about Coroplast? It's light, it's stiff, it's cheap. It's not
particularly UV resistant, but covered with foam and fabric, that shouldn't
be an issue.
For those unfamiliar with the material, Coroplast is like corrugated
cardboard made out of polypropylene. It's available in various thicknesses.
You can pick up small pieces of it at sign shops.
Tim Ward
Old June 12th 04, 07:23 PM
Rich S.
Hmmm...... I remember seeing a wrecked Bonanza (stall on takeoff) with a
complete bite taken out of the top of the panel. I was told it had belonged
to an orthodontist. No, I'm NOT kidding! )
Rich S.
Old June 13th 04, 03:48 AM
On Sat, 12 Jun 2004 08:12:00 -0700, "Tim Ward"
be an issue.
Tim Ward
Have you ever worked with the stuff??? It is as bad as aluminum for
slicing, and it has the distinct disadvantage of being inflexible.
Particularly the stuff used on greenhouses etc.
Old June 13th 04, 12:21 PM
Blueskies
There is a family of RC airplanes that are made from this stuff. Fairly easy to fabricate and pretty tough...
See: http://www.duraplane.com/
Dan D.
http://www.ameritech.net/users/ddevillers/start.html
wrote in message ...
be an issue.
Tim Ward
Old June 13th 04, 06:41 PM
Tim Ward
shouldn't
be an issue.
thicknesses.
Tim Ward
top posting changed to the bottom
"Blueskies" wrote in message
gy.com...
Dan D.
I've gotten paper cuts working with corrugated cardboard, too. Covered with
something, I think it would crush more easily than aluminum. Also, I was
thinking of the thinner 2 mm or 4mm stuff. Don't the greenhouses use 8 or
10 mm thicknesses?
If you slice along the corrugations occasionally, you can get an
approximation of a smooth curve.
On second thought, since you can form it using a heat gun, maybe it wouldn't
be such a hot (hah!) idea. It can get pretty hot in a closed cockpit. It
wouldn't be good if it sagged from the heat
Tim Ward.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
