I'm looking at buying a ASW 27. The ASW 27 are usually 15k less than a ASW 27B, WHY?
Does the ASW 27B have an performance advantage over a ASW 27? |
On Wednesday, December 7, 2016 at 6:54:53 PM UTC-5, Thor wrote:
I'm looking at buying a ASW 27. The ASW 27 are usually 15k less than a ASW 27B, WHY? Does the ASW 27B have an performance advantage over a ASW 27? The B has wet wings which are a little more convenient to fill and may hold a few gallons more.Almost all have newer winglets, either by production, or retrofit. Pricing has little to do with B or otherwise, and is mostly driven by condition and equipment. All other issues being equal, an early 27, with excellent finish condition, can easily be worth more than a B in poorer condition. There is no difference in performance as they are geometrically the same. Good luck UH |
On Thursday, December 8, 2016 at 6:12:30 PM UTC-5, Eric Greenwell wrote:
wrote on 12/7/2016 4:28 PM: On Wednesday, December 7, 2016 at 6:54:53 PM UTC-5, Thor wrote: I'm looking at buying a ASW 27. The ASW 27 are usually 15k less than a ASW 27B, WHY? Does the ASW 27B have an performance advantage over a ASW 27? The B has wet wings which are a little more convenient to fill and may hold a few gallons more.Almost all have newer winglets, either by production, or retrofit. Pricing has little to do with B or otherwise, and is mostly driven by condition and equipment. All other issues being equal, an early 27, with excellent finish condition, can easily be worth more than a B in poorer condition. There is no difference in performance as they are geometrically the same. Good luck UH Are the 27B wings treated differently than the earlier models, so they are less likely to develop "spar dips" from spar shrinkage? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf No- in fact the thicker gluing used on the B's for water protection makes them somewhat more shrink prone from my experience. UH |
Quote:
I suspect it maybe related to the tanks not being properly aired as per AS instructions. Any one had a similar experience? Colin |
On Wednesday, December 7, 2016 at 3:54:53 PM UTC-8, Thor wrote:
I'm looking at buying a ASW 27. The ASW 27 are usually 15k less than a ASW 27B, WHY? Does the ASW 27B have an performance advantage over a ASW 27? Not performance, but other changes: The B model offered an optional tail ballast tank, unavailable on the original. The water ballast dump handle was relocated on the B to a more easily reached and less likely to be elbowed position. There is more Carbon in the B model fuselage layup, making positioning antennas such as FLARM or TXP more critical. As Hank mentioned, Schleicher wing tanks are more likely to cause waviness of the wing skins than ballast bags. Or perhaps most other manufacturers' wing tanks? Also noted previously, the newer winglets work better. There are still a couple of 27s left with the old stubby winglets, but low speed handling is improved by the Tech Note 4 Darlington or Maughmer mod, or Nixon, Nelson, etc. winglets. If you have to do the Tech Note 4 mod, make the tip skids taller at the same time to keep the ailerons out of the dirt, and include tiedown points in the tip skids. Jim |
I'm looking at buying a ASW 27. The ASW 27 are usually 15k less than a ASW 27B, WHY? Does the ASW 27B have an performance advantage over a ASW 27? Does the original ASW 27 have the ability to carry fuselage ballast of 35 liters like in the ASW 27B? |
On Sunday, January 1, 2017 at 12:08:55 AM UTC-5, EricF wrote:
On Wednesday, December 7, 2016 at 3:54:53 PM UTC-8, Thor wrote: I'm looking at buying a ASW 27. The ASW 27 are usually 15k less than a ASW 27B, WHY? Does the ASW 27B have an performance advantage over a ASW 27? Does the original ASW 27 have the ability to carry fuselage ballast of 35 liters like in the ASW 27B? Yes, if equipped with optional fuselage tank. UH |
Hello Thor,
here you can find a side-by-side comparison of the two gliders. http://www.gliderreview.com/comparin...eicher-asw-27b For the rest of the gang: feel free to click on those gray stars to express your opinion and help readers understand those two gliders. No login required! Ciao! -- Jacopo |
If one is thinking of a asw27b is there another make glider one should consider before pulling the trigger?
| Thread Tools | |
| Display Modes | |
