Do Winglets reduce ground effect
Old December 16th 16, 03:12 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Do Winglets reduce ground effect
Not being an aerodynamicist, I was wondering if winglets decreased ground effect. So would an ASW-20 (without winglets) be able to glide further in ground effect than an ASW-20 (with winglets), all else being equal?
Old December 16th 16, 03:23 AM posted to rec.aviation.soaring
Dan Daly[_2_]
On Thursday, December 15, 2016 at 10:12:12 PM UTC-5, Jonathan St. Cloud wrote:
I googled it and this website answers the question https://www.quora.com/Do-aircrafts-w...-ground-effect . Not about the ASW-20 specifically.
It is on the internet, and therefore, must be true.
Old December 16th 16, 04:36 AM posted to rec.aviation.soaring
Michael Opitz
Jonathan St. Cloud
decreased ground
further in
equal?
https://www.quora.com/Do-aircrafts-w...ts-experience-
lesser-ground-effect
Winglets are a way to get most of the benefits of increasing the
span without actually increasing the footprint. The big advantage
for existing aircraft being retrofitted is that winglets don't produce
lift per se, so there is not much change to the bending moments,
therefore the spars don't have to be beefed up as they would for a
straight wing extension. (See the 15-18 m discussion on RAS.) For
airliners with a limited footprint available at gates, winglets allow an
increase in performance with retention of useage of the same gates.
Most general aviation winglets are specifically optimized for that
particular aircraft's cruise speed.
For gliders that have a span limit in their class, winglets are a
(relatively) cheap and easy way to increase performance. The
early glider winglets were generally good at increasing climb
performance, but hindered at the high speed end. The newer
generation of Maughmer type winglets are optimized to perform
much better over a broader speed range in gliders.
So, an ASW-20 with winglets is really like a ~16 meter ASW-20 at
altitude. The winglets probably reduce the ground effect
somewhat, but do they reduce it to a level less than a regular 15m
ASW-20? My guess is that the effects are probably too small for a
pilot to really notice a difference. It might be an interesting
Master's degree project for some grad student who has access to
the wind tunnel time to test the theory out....
There is a whole category of aircraft designed to operate in ground
effect in order to boost their range/payload. They are called WIG
(Wing In Ground effect) aircraft. Some have winglets which are
also pontoons going down, and others have winglets that go up at a
~45 degree angle. I guess the aerodynamic winglet/ground effect
reductiuon question is not settled with these aircraft either. See:
https://www.google.com/search?
q=WIG+aircraft&rlz=1C1CHWA_enUS602US603&espv=2&biw =128
0&bih=918&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahU KEwj
Z0auP7vfQAhVBKGMKHbCTCvsQsAQIMQ#imgrc=_
RO
Old December 16th 16, 06:53 PM posted to rec.aviation.soaring
Jonathan St. Cloud
The reason I asked in the Russell Holtz book, he states that "The closer the wings are to the ground, the more the ground interferes with the development of the wing tip vortices..."
Jonathan St. Cloud
decreased ground
further in
equal?
RO
Old December 16th 16, 06:58 PM posted to rec.aviation.soaring
True. That said, how far the wing is from the ground would have a bigger affect on drag than whether the wing has winglets.
FWIW
UH
Old December 16th 16, 07:09 PM posted to rec.aviation.soaring
The ground can have a reducing effect on winglets, I'm looking at you Voyager.
Old December 16th 16, 08:44 PM posted to rec.aviation.soaring
Michael Opitz
closer
That is because the flow becomes more and more 2 dimensional. The
ground effect goes up exponentially, the closer you get to the ground.
You can measure it in a wind tunnel, but it would be very hard to
measure in an actual glider because a difference of 6" or a foot in
height above the ground would have more of an effect than the
winglets probably do on their own. (presuming that one is already
flying really, really low) At least in a wind tunnel, you can set the
parameters and then make measurements. I don't have my references
handy, but I believe that the ground effect starts to become noticeable
when one is about 1/2 wingspan AGL. It then rapidly increases the
closer one gets to the ground. That is why I think that one won't be
able to see much of a difference with or without winglets. You are in
the area of 3'-4' off the ground, and in that area of the ground effect
curve, being off a foot in height (one way or the other) will make a
much bigger difference on that exponential curve than winglets (or
no winglets) ever will. In real life you just can't fly it that close
unless
you have a real sensitive radio (type) altimeter to measure exactly how
low you are.
RO
Old December 16th 16, 08:59 PM posted to rec.aviation.soaring
Jonathan St. Cloud
It is rainy in Southern California today so continuing on with ground effect. My first and only real experience at needing and losing ground effect was flying a helicopter out of Bishop Airport one hot summer day. Lifting off full of fuel and trying to keep turbine temps in the green, or only brief forays into the yellow, I was just a few feet off the ground building speed after departing helicopter pad, I was doing fine, until I moved off the pavement and was over taller grass. I immediately needed more power as the ground effect suddenly had disappeared.
Old December 16th 16, 04:54 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
There may be lesser benefit from winglets, but you started with more performance, so the end result is likely that you will still have more performance with your winglets in ground effect than without your winglets in ground effect. Assuming your winglets actually boosted your performance. Personally, I don't believe it is entirely proportional to tip vortex strength, but has a lot more to do with downwash field strength. Short spans with big chords get a larger benefit from ground effect than long spans with narrow chords. Just my opinion.
Steve Leonard
Ground effect effectiveness Tony General Aviation 14 January 10th 07 11:17 PM
Ground effect effectiveness Tony Piloting 20 January 10th 07 11:17 PM
Wing in ground effect (blank) Home Built 8 November 19th 05 08:34 AM
Low approaches in ground effect CV Soaring 28 October 21st 04 10:05 PM
Wing in Ground Effect? BllFs6 Home Built 10 December 18th 03 05:11 AM
