Transponder ANPRM Withdrawal
Old December 23rd 16, 04:38 AM posted to rec.aviation.soaring
Eric Bick (ZN7)
Default Transponder ANPRM Withdrawal
Preliminary notification of publication scheduled for December 23.
https://www.federalregister.gov/docu...ers-withdrawal
Old December 23rd 16, 03:25 PM posted to rec.aviation.soaring
Ron Gleason
Thanks for posting this Eric. For those who have not or do not have the time to slog through this document, this to me is the most relevant part of the document
Conclusion
When further testing, research, and conclusive data is available that reflect alternative mitigations, a broader, more harmonized proposal may better serve the public interest. Withdrawal of Notice No. 15-05 does not preclude the FAA from issuing another notice on the subject matter in the future or committing the agency to any future course of action. The agency will make any necessary changes to the regulations through a notice of proposed rulemaking (NPRM) with the opportunity for public comment.
Although the FAA has determined that a regulatory course of action is not warranted at this time, the FAA will continue to work with local glider communities, encourage the voluntary equipage of transponders in gliders and encourage the use of TABS. The FAA continues to recommend that all glider aircraft owners equip their gliders with a transponder meeting the requirements of § 91.215(a), a rule-compliant ADS-B Out system, or a TABS device. In consideration of the above factors, the FAA withdraws Notice No.. 15-05, published in 80 FR 34346, on June 16, 2015.
Old December 23rd 16, 05:35 PM posted to rec.aviation.soaring
Darryl Ramm
One thing that is frustrating is that we might get more installation of TABS devices if there were regulations or a program that allowed their easy installation in *certified* gliders. Especially if its a ~$1k upgrade for folks installing a Mode-S transponder. I'd hope that area is something the FAA actually does work on.
Conclusion
Although the FAA has determined that a regulatory course of action is not warranted at this time, the FAA will continue to work with local glider communities, encourage the voluntary equipage of transponders in gliders and encourage the use of TABS. The FAA continues to recommend that all glider aircraft owners equip their gliders with a transponder meeting the requirements of § 91.215(a), a rule-compliant ADS-B Out system, or a TABS device. In consideration of the above factors, the FAA withdraws Notice No. 15-05, published in 80 FR 34346, on June 16, 2015.
SSA responds to ANPRM David Kinsell[_2_] Soaring 73 August 20th 15 03:29 AM
SSA's planned response to ANPRM Transponders, etc [email protected] Soaring 0 July 11th 15 05:01 AM
ANPRM - removal of transponder exception for gliders [email protected] Soaring 29 June 17th 15 11:00 PM
Withdrawal RFD rec.aviation.questions removal. Jim Riley Instrument Flight Rules 1 July 22nd 07 04:04 AM
Withdrawal RFD rec.aviation.questions removal. Jim Riley General Aviation 0 November 10th 06 10:15 PM
