Exporting Flight Stats from SeeYou
Old December 27th 16, 06:35 PM posted to rec.aviation.soaring
Tony[_5_]
Default Exporting Flight Stats from SeeYou
Looking to analyze a bunch of igc files for our clubs trophy program. These will be flights made throughout the year by club pilots often flying different gliders on different flights. I've investigated using SeeYou Competition for the scoring but it is not designed for this type of year long competition.
Alternative I'm thinking about is finding a way to write the SeeYou statistics to an Excel file where I can then sort to find the highest speed, best altitude gain, etc.
I tried a few suggested Pascal methods of writing to Excel but it seems the Pascal version used in SeeYou Competition does not support this.
Does anyone out there have any ideas on how to get this information extracted? Thanks,
Tony
Old December 27th 16, 07:15 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Tony
Our club defines our awards with respect to the Canadian OLC. I download the 2016 best and all flights Excel files from the OLC. Once there, you can sort by club gliders, private ships, flight length, etc. As a bonus, when you do this, your OLC participation increases.
Dan
2D
Old December 29th 16, 12:18 AM posted to rec.aviation.soaring
Tony[_5_]
Tony
Dan
2D
we have good OLC participation but try to model our club trophies primarily off the sporting code to simulate badge and record flights. speed flights need to be pre-declared (verbal is OK). some trophies are handicapped some are not.
Old December 27th 16, 07:32 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
If you can write the statistics to a CSV (comma-separated variable) file
with a .csv extension, then you can import that into Excel.
The following assumes that you'd want to put the raw stats from each
flight into a separate spreadsheet row.
The only issue with using CSV is that using Excel to combine a set of new
flight stats with the rest of the year's details would be a bit messy,
because it would involve reading the accumulated results into one spread
sheet, each additional set of results into separate spreadsheet(s) and
then using cut'n'paste between sheets to add them to the accumulated
results.
A better way would be to keep the flights database as a CSV file. Then
you can simply append more flight stats to it as you get them, only
pulling the file into Excel for analysis.
Almost every programming language can read and write a properly formatted
CSV file, though the definition of 'properly formatted' can and does vary
a bit, but if you stick to using commas as field separators, enclosing
text fields in double quotes and using normal linefeeds at the end of
each line(row) it should pretty much 'just work', e.g.
# Fields
# Date,Pilot,Glider,N-number,distance(km),Hours,mins
15June2016,"X.C. Pilot","SGS1-26","N12345",300,05,19
extracted? Thanks,
Does this help?
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 28th 16, 08:10 PM posted to rec.aviation.soaring
Stephan van den Berg
I'm also looking for a Excel tool which downloads flights from Soaring Spot or SeeYou and then displays the statistics page from SeeYou for all the flights on any particular day on one page to make analysis between flights easier. I'm thinking of, for example, the following stats:
Speed
Total distance flown
Extra distance flown (total distance flown minus task distance)
Glides
Average glide length
Mean L/D
Ave IAS
Total Climbs
Ave Climb
Tries
Does anyone have something like this to share?
Latest update of SeeYou and OLC flight claims causing problems [email protected] Soaring 6 October 30th 14 07:59 PM
PowerFLARM Flight Circles in SeeYou John Carlyle Soaring 5 June 7th 13 03:02 PM
Flight track playback in Google Earth using SeeYou 4.1 Andy[_10_] Soaring 1 July 1st 11 02:49 AM
SeeYou Flight Display Hal[_2_] Soaring 12 January 11th 09 12:27 PM
OLC 2006 flight uploads with SeeYou Ted Wagner Soaring 2 October 15th 05 05:31 AM
