Glider Maintenance - Fuselage Rotisserie
Old January 6th 17, 01:48 PM posted to rec.aviation.soaring
Papa3[_2_]
Default Glider Maintenance - Fuselage Rotisserie
After years of wandering around northern NJ temporarily occupying the workshops and garages of club members who were kind (or stupid) enough to loan out space, Aero Club Albatross (ACA) finally has a shop of our own at Blairstown airport. As the Refinisher in Chief, I'm building out the infrastructure bit by bit to make sure we are well equipped for future projects. I'm looking for good examples of fuselage fixtures, especially ones that allow for the whole fuselage to be rotated at least 90 degrees either way from vertical.
So, does anyone have examples of a fuselage rotisserie with some photos you can share? We already have a cradle/sling as well as solid stands. We also have used a hoist from the ceiling in the past. Each of these presents some challenges when painting, so we're looking to start fresh. Any pics, sketches, or ideas would be appreciated. We have world class fabricators and machinists in our club, so we can go top tier - no 2x4s and bungee cords. You can email me at erik dot h dot mann @ gmail dot com
Erik Mann (P3)
Old January 6th 17, 04:10 PM posted to rec.aviation.soaring
Contact Paul Gaines at alphazulucomposites dot com. At an SSA convention years ago, I saw a "glider roller" he built, and there is a photo showing one at his shop in Kingman, AZ. Not enough detail to build one, but at least a start.
Old January 6th 17, 04:52 PM posted to rec.aviation.soaring
Erik Mann (P3)
Someone showed some photos of an "octo roller" made from 2 sheets of plywood that picked up front lift pins and rear pins using arms. 8 sided allowed easy rolling to desired position.
I don't remember where I was it. Maybe in the VSA group.
None of these is easy to spray around. For that I hang and tilt 15 degrees or so with a gallon can hung on an arm off lift pins.
FWIW
UH
Old January 6th 17, 06:23 PM posted to rec.aviation.soaring
Jonathon May[_2_]
wor=
loan=
Bla=
infras=
projects.
that
f=
rom vertical. =20
=20
y=
We=
presen=
p=
fabrica=
bunge=
=20
Erik Mann (P3)
plywoo=
allowed
easy rolling to desired position.=20
degrees
FWIW
UH
Somewhere there is a video of a Belgian repair shop rebuilding a broken
Arcus
They have a rig with 2 steel rings and longerons that pick up on the wing
mounts and Cardinal points.they set it to a second new arcus in it and set
points ,then locked it up and fitted the 2 half s of a Brocken arcus to the
same points and re build the bit in the middle
Awesome video if you can find it just build a copy
Old January 6th 17, 09:06 PM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
wor=
loan=
Bla=
infras=
projects.
that
f=
rom vertical. =20
=20
y=
We=
presen=
p=
fabrica=
bunge=
=20
Erik Mann (P3)
plywoo=
allowed
degrees
FWIW
UH
Arcus
Here is that video
https://vimeo.com/60497114
Colin
Old January 6th 17, 09:09 PM posted to rec.aviation.soaring
Papa3[_2_]
Yeah, I had seen this. Still salivating: https://vimeo.com/60497114
Old January 6th 17, 11:53 PM posted to rec.aviation.soaring
JS
P3, I dug this up from the archives. Link below.
A photo scanned from the August 23rd 1991 "Hollywood Reporter" article on soaring, "The Quiet Ride".
It shows an ASW20 - without the taily bit - in the rotisserie at Glass Teck Unlimited. And Rick Wagner with arms folded. Nostalgia for R12 folks.
Also visible is Rick's model of "Rare Bear", of course its analog R/C failed impressively at high speed!
Bonus: If you look in the folder with a familiar name, there may be soaring cartoons for winter reading.
https://www.dropbox.com/sh/0gh8y9b7p...ykXOTBjEa?dl=0
Old January 6th 17, 08:06 PM posted to rec.aviation.soaring
Jonathon May[_2_]
wor=
loan=
Bla=
infras=
projects.
that
f=
rom vertical. =20
=20
y=
We=
presen=
p=
fabrica=
bunge=
=20
Erik Mann (P3)
plywoo=
allowed
degrees
FWIW
UH
Sorry my las post was inaccurate ,it was a soaring cafe piece
http://vimeo.com/60497114
Jon
Old January 6th 17, 08:29 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Erik Mann (P3)
HP-24 project photo pages; 18 May 2014 - plywood octogon. https://www.facebook.com/20093135495...549952/?type=3
Feb 26/2015 - Great and Terrible Infinigon. https://www.facebook.com/20093135495...type=3&theater
Always a great browse.
Old January 6th 17, 08:53 PM posted to rec.aviation.soaring
Bob Kuykendall
Thanks, you beat me to it! --Bob K.
looking for damaged unflyable tandem glider fuselage and canopy touse as body for a 3 wheeld electric car. [email protected] Soaring 4 October 25th 15 03:18 PM
Engine maintenance of a motor glider kd6veb Soaring 0 October 13th 13 05:57 PM
German registered glider maintenance: help with LBA doc needed Ludovic Launer[_2_] Soaring 3 July 19th 08 10:43 AM
Looking for a fuselage Jay Honeck Home Built 79 March 7th 05 01:42 PM
Looking for a fuselage Jay Honeck Aviation Marketplace 72 March 7th 05 01:42 PM
