ASW 24&27 rear fuselarge vents?
Old October 23rd 03, 04:48 PM
Udo Rumpf
Default ASW 24&27 rear fuselarge vents?
Hi all,
to day I checked, what I thought was the rear exhaust vent of the ASW24.
I tried, after removing the rudder, insert a thin wire past the tail wheel fender.
I could not get this thin flexible wire through.
I inserted a long vacuum hose from the cockpit side, to the very end of the tail
and hook up the blower side. The results were feeble indeed.
What have other ASW 24 or 27 owners done to improve this situation?
Regards
Udo
Old October 23rd 03, 05:40 PM
John Morgan
"Udo Rumpf" wrote in message
Hi all,
fender.
tail
Regards
Udo
Udo,
I suspected exhaust venting may be limiting cockpit ventilation on my
ASH26E. I haven't finished testing yet, but what I have done is to hook up a
shop-vac, on blow mode (after carefully cleaning it!), to the nose inlet to
pressurize the cockpit. I didn't have the wings attached, so taped up all
the fuselage wing root openings. The only outflow I could detect was at the
rudder cable fairing at the tail - - nothing at the gear or engine bay
doors.
On my non-scientific test, the flow was obviously restricted (the shop-vac
puts out a lot of air) as my temporary wing root covers ballooned out from
the pressure.
I plan to check cockpit vent flow with and without a temporary reverse scoop
in the plexi window etc. And also repeating the shop-vac test with wings
attached to make sure none is leaking out through wing openings - - I doubt
it is.
I've seen a picture of a 26E with a reverse facing, flush scoop on the lower
cockpit fuselage side . . . so others have dealt with this issue and come up
with solutions of their own. Any other info would be welcome . . .
bumper - ZZ
"Dare to be different . . . circle in sink."
to reply, the last half is right to left
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.525 / Virus Database: 322 - Release Date: 10/9/2003
Old October 24th 03, 12:09 AM
JJ Sinclair
Hi Udo,
My ASH-25 was emitting a very loud squeal as I went through the finish gate at
redline (above 500 feet of course). I removed the rudder and found no way for
vent air to get out, so I drilled a 1" X 2" hole in the tail wheel fender.
Worked fine and the cockpit ventilation got a bunch better. As you know, the
exit hole should be 1.5 times the entry hole size.
On my nimbus 3, I enlarged the hole in the vertical fin spar and also polished
out the rudder cable exit guides with a sanding roll on a rod, driven by a
drill motor. Unfortunately, some major sailplane manufacturers don't do much,
if anything, about providing an efficient airflow exit system and if we don't
let it out in the tail area, the vent air will go looking for a way out in
other places, like the wings, landing gear doors and canopy seal.
JJ Sinclair
Old October 24th 03, 12:18 AM
Greg Arnold
JJ Sinclair wrote:
Hi Udo,
Do all manufacturers ignore exit air? If not, which ones take this into
account in their designs?
and if we don't
JJ Sinclair
Old October 24th 03, 12:44 AM
Udo Rumpf
gate at
for
polished
much,
don't
JJ Sinclair
Old October 24th 03, 01:02 AM
Udo Rumpf
Sorry about the previous message.
I became suspicious when I noticed reams of foam
around the canopy as well as the cockpit opening,
to the point that the canopy would not line up along the fuselage line,
The brass bushing that holds the canopy down and locked was worn out, I
assume because of it.
I have a generous exit vent on my other glider and no seal on the canopy.
The fit is no better or worse than any other glider, still the cockpit is
relatively quiet through out the speed range.
Udo
Meting with a Lancaster rear gunner Dave Eadsforth Military Aviation 12 November 22nd 03 08:08 AM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 07:35 AM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 03:04 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 09:14 AM
Why not a Quad Tiltrotor Pusher-Puller? Blair Maynard Naval Aviation 4 July 2nd 03 07:52 AM
