Looking for ballast bags PIK-20 USA
Old January 27th 17, 01:35 PM posted to rec.aviation.soaring
Wit Wisniewski
Default Looking for ballast bags PIK-20 USA
Hello folks,
My PIK-20B bags need replacing. Does anyone have suitable bags for sale?
- I am considering manufacture and have contacted Guy Achard / Airsolid. Are there any other fabricators?
- The 20B is allowed to carry 140 Liters, but the bag drawing on trafi.fi show a bag labeled 60L. Why the discrepancy? This bag has an internal volume of 100 Liters when inflated outside the wing.
- There was a 140 Liter retrofit kit (factory?) available for the 20. Does anyone have documentation for its bag dimensions?
- I will consider buying any bags that have appropriate dimensions. I have heard that ASW-24 bags fit well.
Thanks in advance,
Wit Wisniewski
Tucson, Arizona
Old January 27th 17, 02:31 PM posted to rec.aviation.soaring
I have had bags made to order by Streifeneder in Germany. Fifteen gallon bags for $350'ish. He needs length, width at root and tip + fill tube diameter.
BTW, he owns the rights to all Glassflugel ships and has parts, like landing gears, etc. He has also sent me 92110 fiberglass cloth. Good guy to knowinfo(at)streifly.de
JJ
Old January 27th 17, 03:00 PM posted to rec.aviation.soaring
Dan Daly[_2_]
On Friday, January 27, 2017 at 8:35:44 AM UTC-5, Wit Wisniewski wrote:
Hello folks,
Thanks in advance,
Wit Wisniewski
Tucson, Arizona
AMS flight sells two sizes: http://www.ams-flight.si/index.php?p...mid=96&lang=en
Streifeneder can make them:
http://www.streifly.de/shop%20wassersack-e.htm
Old January 27th 17, 04:04 PM posted to rec.aviation.soaring
Why are you linking a DG series glider? OP is looking for a PIK.
Old January 29th 17, 05:20 PM posted to rec.aviation.soaring
firsys
Hello folks,
Thanks in advance,
Wit Wisniewski
Tucson, Arizona
Old January 29th 17, 05:26 PM posted to rec.aviation.soaring
firsys
Hello folks,
Thanks in advance,
Wit Wisniewski
Tucson, Arizona
ex PIK 20E bags plasticised fabric, never used, excellent condition, carefully stored. Hoses included. Leak tested.
root 27cm, outboard 25 cm length 350 cm.
$250 US
John F
ballast bags FS firsys Soaring 0 May 16th 16 08:27 PM
Water Ballast Bags - Need Source YourNameHere Soaring 0 June 22nd 14 09:33 PM
DG-300 Water Ballast Bags noel.wade Soaring 7 February 18th 10 02:39 AM
Leaking water ballast bags Itsaplane[_2_] Soaring 7 June 14th 09 02:44 AM
NEED BALLAST BAGS [email protected] Soaring 3 June 12th 06 05:04 AM
