cobra trailer style wing beds
Old January 30th 17, 03:07 PM posted to rec.aviation.soaring
Scott Williams
Default cobra trailer style wing beds
Does anyone know how long the wing leading edge trailer beds should be for a std cirrus? I want to replace the pheiffer trailer wing cuffs with cobra style beds to decrease the ground handling gear count and ease the use of a wing rigger.
thanks,
Scott w.
N8915
Old January 30th 17, 03:17 PM posted to rec.aviation.soaring
thanks,
Scott w.
N8915
We made some for a St Cirrus going in a Komet. They were 15 inches long. We made a mold from aluminum and laid up 8 plies of 8 oz cloth. Felt came from McMaster Carr.
When planning this look at the wing dollies and make sure they will go over your saddles. Most likely they will need to be altered.
This can be a very nice improvement, but plan the details.
Good Luck
UH
Old February 1st 17, 03:36 PM posted to rec.aviation.soaring
Scott Williams
thanks,
Scott w.
N8915
Good Luck
UH
Thanks UH,
Good points.
Scott W.
Old February 1st 17, 09:11 PM posted to rec.aviation.soaring
bumper[_4_]
It's often convenient to add a second leading edge pad further towards the rear of the trailer so you can move the wing back far enough to access the cockpit without removing the fuselage.
Also consider draping a microfiber cloth over the pad to avoid wing surface abrasion caused by dirt on the original pad surface - you can wash the cloth now and then.
bumper
Old February 2nd 17, 01:25 AM posted to rec.aviation.soaring
Scott Williams
bumper
(2nd pad further towards the rear),
On the span where do the pads usually lie? 3/4 out from root?
Scott W.
Old February 2nd 17, 04:52 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
bumper
Scott W.
Hi Scott
My Ventus maintenance manual specifies 2.5m in from the tip for a wing bed although it doesn't specify a length for it. UH's suggestion sounds real good to me for the size of it
Your Cirrus maintenance manual may well have some guidance in the section on storage, transport and rigging.
:-) Colin
Old February 2nd 17, 03:06 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Scott W.
On a wing with no change in taper along the leading edge (like on your Std Cirrus), I would put the one and only about at the root of the aileron. For simplicity's sake, you could center it on the root of the aileron. With a change in taper on the leading edge, immediately inboard of the taper change. You don't want to be too far outboard, as this puts a larger compression load into the rear spar during travel down that bumpy road. You also don't want it too far inboard, as then the entire weight of the wing will be resting on that little section of leading edge for the bumpy road.
Having troubles seeing how you could "pull the wing out far enough to access the cockpit without pulling the fuselage out." This would require pulling a wing back, crawling in the front door, around the nose ring, possibly also the spare tire, then back to the cockpit. Then, how much can you open the canopy inside the trailer? Seems to me to be MUCH easier to pull the fuselage out. I saw an LS3 get a scrape on the bottom of a newly refinished wing when the owner tried to pull the wing out with the fuselage still in place. Komet trailer. Was working on the dive brakes.
Do like the idea of the cloth in the cradle.
Steve Leonard
BruceGreeff
The Std Cirrus has tiedown bolt holes that double up to retain the wing
in the trailer dolly.
When you pull the wing back, the dolly is secured to the wing, and rolls
back with it.
There is very little movement because of the positive location.
Bruce
On 2017-02-02 06:52, Ventus_a wrote:
Scott Williams;937104 Wrote:
On Wednesday, February 1, 2017 at 3:11:44 PM UTC-6, bumper wrote:-
bumper-
Scott W.
Hi Scott
:-) Colin
Bruce Greeff
T59D #1771
Old February 2nd 17, 04:22 PM posted to rec.aviation.soaring
back with it.
Bruce
bumper-
Scott W.
Hi Scott
:-) Colin
Bruce- read the thread. He is putting a change in to eliminate those saddles.
UH
Bruce Greeff
T59D #1771
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
Cobra trailer wing dolly plastic sidewall rollers? [email protected] Soaring 4 May 9th 13 10:52 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
COBRA TRAILER Gordon Schubert[_2_] Soaring 0 February 10th 09 04:15 AM
WTB: Cobra Trailer for LS-4 [email protected] Soaring 0 July 31st 08 05:04 PM
