GPU conversions
Old June 12th 04, 10:16 PM
Sean Trost
Default GPU conversions
Hi all what would be involved in converting a GPU to a usable aircraft
powerplant ?
looking specifically at the O-290.
Ive googled and not come up with much.
Thanks in advance.
Sean Trost
Old June 13th 04, 12:12 AM
Ed Wischmeyer
powerplant ?
That's really an ancient question! A good bet is to contact EAA (you are a
member, of course) and get references from them -- old copies of Sport
Aviation (now available on CD-ROM), and maybe a dedicated book on the
topic.
Ed WIschmeyer
Member, EAA Homebuilt Aircraft Council
Old June 13th 04, 01:32 AM
jerry Wass
I gots one of them there how to convert books, It's 9 years older'n God,
but so's the engine--I'll send you a little pitcher of it & yew can
see---yew better price all the parts you might need for o/haul berfore you
decide---they's a gittin scarce....
powerplant ?
Thanks in advance.
Sean Trost
Old June 13th 04, 01:41 AM
Cy Galley
At one time the EAA had a manual on the procedure and may still be
available. Ken Brock used to machine the cases to remove the heavy mounting
flange and add a second mag drive. The O-290 crank has a light prop flange
that is prone to cracking. Aircraft Spruce and Ken Brock both sell a
re-inforcement plate. See p172 of the current Aircraft Spruce catalog.
If you want this engine, I know there are many of them just languishing in
the back of hangars. I have a friend that flew his LongEze for many trouble
free hours before he replaced it with an O-320. I believe the parts are
getting harder to find and more expensive was the basic reason he didn't
overhaul it.
Cy Galley
Safety Programs Editor
EAA Sport Pilot
"Sean Trost" wrote in message
. com...
powerplant ?
Thanks in advance.
Sean Trost
Old June 13th 04, 03:46 PM
Sean Trost
Thanks to all who responded.
The Motor in Question is on Ebay right now For those interested. I have
decided to wait and try and score a 320 or 360 somehow.
Sean Trost
powerplant ?
Thanks in advance.
Sean Trost
Old June 13th 04, 11:26 PM
Gordon Arnaut
Sean, where is that O-290 GPU on eBay.
I searched but couldn't find it.
Regards,
Gordon.
Sean Trost
powerplant ?
Thanks in advance.
Sean Trost
Old June 13th 04, 11:53 PM
Sean Trost
Gordon,
looks to me like it has two mags on it. and an aircraft sump. so
mebeee not a GPU.
its item #2481925834
good luck
Sean
Regards,
Gordon.
Sean Trost
powerplant ?
Thanks in advance.
Sean Trost
Old June 14th 04, 03:32 AM
Bob Kuykendall
Earlier, Sean Trost wrote
...and an aircraft sump...
I disagree. The downdraft carb behind the accessory case is one of the
hallmarks of the O-290G, so I believe that it still has the GPU sump.
Also, the heavy crankcase flange at the crank output is another O-290G
giveaway.
It _does_ look like it has two mags, and that's a puzzler to me.
Thanks, and best regards to all
Bob K.
http://www.hpaircraft.com/hp-24
Old June 14th 04, 04:29 AM
jerry Wass
I say,Gov'nr, ---if you remove the governor, you can install another mag.
giveaway.
Bob K.
Old June 15th 04, 06:01 AM
Bob Kuykendall
Ah, so that's what that beastie is. Thanks!
Bob K.
V-8 powered Seabee Corky Scott Home Built 212 October 2nd 04 11:45 PM
Harley engine special Brett Home Built 106 May 28th 04 03:10 AM
Auto conversions & gear boxes Dave Covert Home Built 56 April 1st 04 06:19 PM
VW conversions John McFarlane Home Built 3 November 5th 03 01:03 AM
