https://en.wikipedia.org/wiki/De_Havilland_Mosquito
The de Havilland DH.98 Mosquito is a British multi-role combat aircraft with a two-man crew which served during and after the Second World War. It was one of few operational front-line aircraft of the era constructed almost entirely of wood and was nicknamed "The Wooden Wonder". The Mosquito was also known affectionately as the "Mossie" to its crews. Originally conceived as an unarmed fast bomber, the Mosquito was adapted to roles including low to medium-altitude daytime tactical bomber, high-altitude night bomber, pathfinder, day or night fighter, fighter-bomber, intruder, maritime strike aircraft, and fast photo-reconnaissance aircraft. It was also used by the British Overseas Airways Corporation (BOAC) as a fast transport to carry small high-value cargoes to, and from, neutral countries, through enemy-controlled airspace.[6] A single passenger could be carried in the aircraft's bomb bay, which was adapted for the purpose. Overview The Mosquito was a fast, twin-engined aircraft with shoulder-mounted wings.[60] The most-produced variant, designated the FB Mk VI (Fighter-bomber Mark 6), was powered by two Merlin Mk 23 or Mk 25 engines driving three-bladed de Havilland hydromatic propellers. The typical fixed armament for an FB Mk VI was four Browning .303 machine guns and four 20 mm Hispano cannon while the offensive load consisted of up to 2,000 pounds (910 kg) of bombs, or eight RP-3 unguided rockets.[61] The design was noted for having light and effective control surfaces which allowed for good manoeuvrability, but that the rudder should not be used aggressively at high speeds; poor aileron control at low speeds when landing and taking off was also a problem for inexperienced crews.[62] For flying at low speeds, the flaps had to be set at 15°, speed reduced to 201 miles per hour (323 km/h) and rpm set to 2,650. The speed could be reduced to an acceptable 150 miles per hour (240 km/h) for low speed flying.[63] For cruising the maximum speed for obtaining maximum range was 200 miles per hour (320 km/h) at 17,000 lb (7,700 kg) weight. Specifications DH.98 Mosquito F Mk II Fighter version. Data from Mosquito and Mosquito Performance trials General characteristics Crew: 2: pilot, navigator/radar operator Length: 41 ft 2 in (13.57 m) Wingspan: 54 ft 2 in (16.52 m) Height: 17 ft 5 in (5.3 m) Wing area: 454 ft2 (42.18 m2) Empty weight: 13,356 lb (6,058 kg) Loaded weight: 17,700 lb (8,028 kg) Max. takeoff weight: 18,649 lb (8,549 kg) Powerplant: 2 × Rolls-Royce Merlin 21/21 or 23/23 (left/right) liquid-cooled V12 engine, 1,480 hp (21 & 23) (1,103 kW) each Performance Maximum speed: 318 kn (366 mph (589 km/h)) at 21,400 ft (6,500 m)[170] Range: 782 nmi (900 mi (1,400 km)) with 410 gal (1,864-litre) fuel load at 20,000 ft (6,100 m) Service ceiling: 29,000 ft (8,839 m) Rate of climb: 1,740 ft/min (8.8 m/s) Wing loading: 39.9 lb/ft2 (195 kg/m2) Power/mass: 0.189 hp/lb (311 W/kg) Armament Guns: 4 × 20 mm (.79 in) Hispano Mk II cannon (fuselage) and 4 × .303 in (7.7 mm) Browning machine guns (nose) Avionics AI Mk IV or Mk V radar (NF variants) DH.98 Mosquito B Mk XVI The definitive bomber version. Data from Jane's Fighting Aircraft of World War II[171] and World War II Warbirds General characteristics Crew: 2: pilot, bombardier/navigator Length: 44 ft 6 in (13.57 m) Wingspan: 54 ft 2 in (16.52 m) Height: 17 ft 5 in (5.3 m) Wing area: 454 ft2 (42.18 m2) Empty weight: 14,300 lb (6,490 kg) Loaded weight: 18,100 lb (8,210 kg) Max. takeoff weight: 25,000 lb (11,000 kg) Powerplant: 2 × Rolls-Royce Merlin 76/77 (left/right) liquid-cooled V12 engine, 1,710 hp (1,280 kW) each Performance Maximum speed: 361 kn (415 mph (668 km/h)) at 28,000 ft (8,500 m) Range: 1,300 nmi (1,500 mi (2,400 km)) with full weapons load Service ceiling: 37,000 ft (11,000 m) Rate of climb: 2,850 ft/min (14.5 m/s) Wing loading: 39.9 lb/ft2 (195 kg/m2) Power/mass: 0.189 hp/lb (311 W/kg) Armament Bombs: 4,000 pounds (1,800 kg) Avionics GEE radio-navigation * |
| Thread Tools | |
| Display Modes | |
| Cockpits...file name same as aircraft type [10/21] - De Havilland Mosquito Cockpit.jpg (1/1) | Miloch | Aviation Photos | 0 | June 20th 16 05:04 PM |
| Australian De Havilland Mosquito A52-312 (ex A52-203) | TacAN | Aviation Photos | 0 | February 8th 08 10:49 AM |
| De Havilland TK 3 | [email protected] | Aviation Photos | 2 | June 1st 07 09:30 AM |
| De Havilland 110 | Leslie | Aviation Photos | 1 | March 25th 07 02:46 AM |
