https://en.wikipedia.org/wiki/Convair_B-58_Hustler
The Convair B-58 Hustler was the first operational supersonic jet bomber capable of Mach 2 flight. The aircraft was designed by Convair engineer Robert H. Widmer and developed for the United States Air Force for service in the Strategic Air Command (SAC) during the 1960s. It used a delta wing, which was also employed by Convair fighters such as the F-102, with four General Electric J79 engines in pods under the wing. It carried five nuclear weapons; four on pylons under the wings, and one nuclear weapon and fuel in a combination bomb/fuel pod under the fuselage, rather than in an internal bomb bay. Replacing the Boeing B-47 Stratojet medium bomber, it was originally intended to fly at high altitudes and supersonic speeds to avoid Soviet fighters. The B-58 received a great deal of notoriety due to its sonic boom, which was often heard by the public as it passed overhead in supersonic flight. The introduction of highly accurate Soviet surface-to-air missiles forced the B-58 into a low-level penetration role that severely limited its range and strategic value, and it was never employed to deliver conventional bombs. This led to a brief operational career between 1960 and 1970 when the B-58 was succeeded by the smaller, swing-wing FB-111A The B-58 crews were chosen from other strategic bomber squadrons. Due to some characteristics of delta-winged aircraft, new pilots used the Convair F-102 Delta Dagger as a conversion trainer, before moving to the TB-58A trainer.[24] The B-58 was difficult to fly and its three-man crews were constantly busy, but its performance was exceptional. A lightly loaded Hustler would climb at nearly 46,000 ft/min (235 m/s).[25] In addition to its much smaller weapons load and more limited range than the Boeing B-52 Stratofortress, the B-58 had also been extremely expensive to acquire. Specifications (B-58A) General characteristics Crew: 3: pilot; observer (navigator, radar operator, bombardier); defense system operator (DSO; electronic countermeasures operator and pilot assistant). Length: 96 ft 10 in[66] (29.5 m) Wingspan: 56 ft 9 in[66] (17.3 m) Height: 29 ft 11 in (8.9 m) Wing area: 1,542 ft² (143.3 m²) Airfoil: NACA 0003.46-64.069 root, NACA 0004.08-63 tip Empty weight: 55,560 lb (25,200 kg) Loaded weight: 67,871 lb (30,786 kg) Max. takeoff weight: 176,890 lb (80,240 kg) Powerplant: 4 × General Electric J79-GE-5A turbojet Dry thrust: 10,400 lbf dry thrust (52.9 kN) () each Thrust with afterburner: 15,600 lbf (69.3 kN) each Zero-lift drag coefficient: 0.0068 Drag area: 10.49 ft² (0.97 m²) Aspect ratio: 2.09 Performance Maximum speed: Mach 2.0[66] (1,319mph) at 40,000 ft (12,000 m) Cruise speed: 610 mph (530 kn, 985 km/h) Combat radius: 1,740 mi (1,510 nmi, 3,220 km) Ferry range: 4,100 nmi (4,700 mi, 7,600 km) Service ceiling: 63,400 ft (19,300 m) Rate of climb: 17,400 ft/min (88 m/s) at gross weight[67] Wing loading: 44.0 lb/ft² (215 kg/m²) Thrust/weight: 0.919 lbf/lb Lift-to-drag ratio: 11.3 (subsonic, "clean configuration") Armament Guns: 1× 20 mm (0.79 in) T171 cannon[66] Bombs: 1× B53 or 4× B43 or B61 nuclear bombs; maximum weapons load was 19,450 lb (8,820 kg) Avionics AN/APB-2 Bombing radar[68] AN/APN-110 Doppler navigational radar[69] (part of Sperry AN/ASQ-42 Navigation & Bombing System)[70] AN/APN-170 Terrain-following radar[69] AN/APR-12 Radar warning receiver[71] Hughes Aircraft AN/APQ-69 podded Side looking airborne radar (mounted on RB-58A)[72] Goodyear AN/APS-73 podded synthetic aperture radar (mounted on RB-58A) |
| Thread Tools | |
| Display Modes | |
| Convair 240 | Glenn[_4_] | Aviation Photos | 0 | March 11th 13 10:20 AM |
| Convair 580 VH-PDV 3 of 3 | TacAN | Aviation Photos | 0 | May 22nd 08 02:02 AM |
| Convair 580 VH-PDV 2 of 3 | TacAN | Aviation Photos | 0 | May 22nd 08 02:01 AM |
| The Hustler, concluded - Hustler.jpg (1/1) | Mitchell Holman[_2_] | Aviation Photos | 1 | March 9th 07 01:33 AM |
| Convair NX-2? | Capt. Doug | Piloting | 5 | September 15th 05 02:58 AM |
