Serusly, maybe Dr. Jack can log in with his forecast of when he thinks
real-time moving map cockpit displays of current thermals, or (let's not be unreasonable here) 1-hr old thermals will be available. Or does he think there is a physical limit to this problem, beyond which we cannot go? (Like 7 A-h batteries) Winter food for thot BJ |
How about this to help you make the best of thermals
you have bumped into. Does anyone have any practical experience of this device ? http://www.themi.de/Themi%20Centering%20Device.htm Anyone used the Winpilot Pro Climb maximiser, does it work ? John At 16:54 19 November 2003, Bob Johnson wrote: Serusly, maybe Dr. Jack can log in with his forecast of when he thinks real-time moving map cockpit displays of current thermals, or (let's not be unreasonable here) 1-hr old thermals will be available. Or does he think there is a physical limit to this problem, beyond which we cannot go? (Like 7 A-h batteries) Winter food for thot BJ |
All
As I'm still trying to make Silver distance I well appreciate the desire for a thermal road map. However, mystery is part of the marvel of soaring. For certainty all one need do is fill the tanks on a power plane and go. No mystery in that. Tom Knauff reports the Themi works. See eglider.com for a review. Regards Rod |
Bob Johnson wrote:
Serusly, maybe Dr. Jack can log in with his forecast of when he thinks real-time moving map cockpit displays of current thermals, or (let's not be unreasonable here) 1-hr old thermals will be available. Or does he think there is a physical limit to this problem, beyond which we cannot go? (Like 7 A-h batteries) The first thing that needs to be established is data uplink to a glider so that _presently_ existing observations (eg satellite images) or predictions (eg updated BLIPMAPs) can be obtained, and I'm not an expert on when that will occur. (Milt Hare used to solve the updating problem by calling his glider-rated wife from the air and having her describe the latest BLIPMAP predictions to him, but I don't think that will be a common practice!). Observation of individual thermals is difficult enough for researchers (typically taking two lidar/radars) so I can't see that being feasible in my lifetime, and in any case thermals have relatively short lifetimes - what would be more practical would be observation of the general "convective status" at specific locations, which is possible using special temperature-profile sounders (not the sounders used for upper-level wind speeds) - but at present those are few and far between (an example of such sounder output can be seen at http://www.weather.nps.navy.mil/profiler/ord_mix.gif ) -- Dr. John W. (Jack) Glendening Meteorologist |
The closest thing I have seen for thermal locators is WinPilot's data
base for thermals. you can enter as many thermals for a site that you want to and have a read out on you PocketPC Winpilot program that shows where thermals have historically been located given a particular day, time of day and wind variables. Works pretty good, but if you have flown many years at one site you know where the thermals are anyway, if there are any thermals that is. G. Kemp DrJack wrote in message ... Bob Johnson wrote: Serusly, maybe Dr. Jack can log in with his forecast of when he thinks real-time moving map cockpit displays of current thermals, or (let's not be unreasonable here) 1-hr old thermals will be available. Or does he think there is a physical limit to this problem, beyond which we cannot go? (Like 7 A-h batteries) The first thing that needs to be established is data uplink to a glider so that _presently_ existing observations (eg satellite images) or predictions (eg updated BLIPMAPs) can be obtained, and I'm not an expert on when that will occur. (Milt Hare used to solve the updating problem by calling his glider-rated wife from the air and having her describe the latest BLIPMAP predictions to him, but I don't think that will be a common practice!). Observation of individual thermals is difficult enough for researchers (typically taking two lidar/radars) so I can't see that being feasible in my lifetime, and in any case thermals have relatively short lifetimes - what would be more practical would be observation of the general "convective status" at specific locations, which is possible using special temperature-profile sounders (not the sounders used for upper-level wind speeds) - but at present those are few and far between (an example of such sounder output can be seen at http://www.weather.nps.navy.mil/profiler/ord_mix.gif ) |
Thermals can be found in rather predictable locations in the mountains, but how
do these *thermal finders* work over flat country, say Hobbs or Uvalde? JJ Sinclair |
DrJack --
I took the liberty of truncating your url and came up with this record: http://www.weather.nps.navy.mil/profiler/r07_sfc.gif The second bar of 24-hr data "deg" shows a background of Westerly winds until about 10:00 UTC (1 PM? local), when shifts around the compass are seen. These shifts persist until around local sundown. Could these shifts be "convective status" markers from the profiler? Another story (good grief, will they never stop?): Wally Scott was limited by car tows to only collecting more Barringer Trophies than his wife had room for on the walls of their home. He would wait at the end of the runway with his ship hooked up to his Chevy station wagon until one or more of the runway windsocks started to droop and point away from the prevailing wind. This was his signal for "OK, Boots, slack's out, let's go". And he was gone. I guess a space-based Doppler Lidar would be hard pressed to to determine a surface convective reflection through all the intervening atmospheric layers? http://www.ghcc.msfc.nasa.gov/sparcl..._tutorial.html Thanks for your answer, Bob Johnson Midland, Texas DrJack wrote: Bob Johnson wrote: Serusly, maybe Dr. Jack can log in with his forecast of when he thinks real-time moving map cockpit displays of current thermals, or (let's not be unreasonable here) 1-hr old thermals will be available. Or does he think there is a physical limit to this problem, beyond which we cannot go? (Like 7 A-h batteries) The first thing that needs to be established is data uplink to a glider so that _presently_ existing observations (eg satellite images) or predictions (eg updated BLIPMAPs) can be obtained, and I'm not an expert on when that will occur. (Milt Hare used to solve the updating problem by calling his glider-rated wife from the air and having her describe the latest BLIPMAP predictions to him, but I don't think that will be a common practice!). Observation of individual thermals is difficult enough for researchers (typically taking two lidar/radars) so I can't see that being feasible in my lifetime, and in any case thermals have relatively short lifetimes - what would be more practical would be observation of the general "convective status" at specific locations, which is possible using special temperature-profile sounders (not the sounders used for upper-level wind speeds) - but at present those are few and far between (an example of such sounder output can be seen at http://www.weather.nps.navy.mil/profiler/ord_mix.gif ) -- Dr. John W. (Jack) Glendening Meteorologist |
Bob Johnson wrote:
I took the liberty of truncating your url and came up with this record: http://www.weather.nps.navy.mil/profiler/r07_sfc.gif Those are surface measurements from a normal set of surface weather sensors. The one you mention is surface wind direction, the dramatic changes being onshore/offshore sea-breeze flow since the site is located within 2 miles of the ocean. -- Dr. John W. (Jack) Glendening Meteorologist |
Check out the thermal finder in WinPilot. WinPilot XP takes logger flights,
IGC files, and produces a thermal data base. You need to have WinPilot XP for your desktop computer and WinPilot ADV or PRO for your Ipaq. I personally have six years of data for Montague and all the contest flights in the area, in my Montaque thermal data base. WinPilot can be set to limit the thermals by sun position and wind direction. The thermals can be turned on and off by assigning a button on the front of the Ipaq. Many contest flights are available for download for most US contest sites. One interesting thing is the thermals that were found by contest pilots in areas that locals very rarely fly. I believe there is also a thermal data base available for the Minden area. I will add a thermal database page for WinPilot users to my website in the next couple of days. If you have a thermal database for you area and want it placed on my web please email it to me. Richard www.craggyaero.com "Bob Johnson" wrote in message ... Serusly, maybe Dr. Jack can log in with his forecast of when he thinks real-time moving map cockpit displays of current thermals, or (let's not be unreasonable here) 1-hr old thermals will be available. Or does he think there is a physical limit to this problem, beyond which we cannot go? (Like 7 A-h batteries) Winter food for thot BJ |
I heard about this feature of WinPilot at the SSA convention
earlier this year. Amazing. Now, it will be interesting to see the effect to the database(s) as land-use changes take place. What happens to the burned areas (California?) or timbered areas or locations that were purely agricultural and change to residential or commercial? I don't have WinPilot, but I think it would be interesting to know what happens. Ray Lovinggood Carrboro, North Carolina, USA At 15:12 20 November 2003, Richard Pfiffner wrote: Check out the thermal finder in WinPilot. WinPilot XP takes logger flights, IGC files, and produces a thermal data base. You need to have WinPilot XP for your desktop computer and WinPilot ADV or PRO for your Ipaq. I personally have six years of data for Montague and all the contest flights in the area, in my Montaque thermal data base. WinPilot can be set to limit the thermals by sun position and wind direction. The thermals can be turned on and off by assigning a button on the front of the Ipaq. Many contest flights are available for download for most US contest sites. One interesting thing is the thermals that were found by contest pilots in areas that locals very rarely fly. I believe there is also a thermal data base available for the Minden area. I will add a thermal database page for WinPilot users to my website in the next couple of days. If you have a thermal database for you area and want it placed on my web please email it to me. Richard www.craggyaero.com |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Rotorcraft | 0 | April 29th 04 08:29 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Naval Aviation | 0 | April 29th 04 08:09 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | General Aviation | 0 | April 29th 04 08:09 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Military Aviation | 0 | April 29th 04 06:45 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Home Built | 0 | April 29th 04 06:43 PM |
