LXNAV Nano4 - Quick Review
Old February 28th 17, 05:01 PM posted to rec.aviation.soaring
Paul Remde
Default LXNAV Nano4 - Quick Review
Hi,
I received the first batch of Nano4 units yesterday. They have all
been sold, but more should arrive in a week or 2.
I'm extremely impressed with the Nano4. It is easy-to-use and
the display of airports and airspace and FLARM data only makes the
screen clear and uncluttered. It is a very high resolution display for
its size - so it looks very sharp.
It has a very bright display. I just walked outside in sunlight with
an Oudie IGC (same screen as Oudie 2) and Nano4 and the Nano4 is a bit
brighter than the already very bright Oudie IGC.
The Nano4's screen is about 2/3 as tall and 3/4 as wide as the
Oudie screen. The Nano4 doesn't display terrain elevation maps,
cities, rivers, lakes, etc. and doesn't have a terrain elevation
database, so it can't display altitude AGL like the Oudie can - that
keeps the Nano4's display uncluttered.
To change a Navbox, you simply tap and hold on the navbox for a second
and then lift off it. Large icons for each navbox option are easy to
select with a fingertip.
To change the MacCready setting, you just tap on it. It is displayed
on the right side of the screen in the middle. Then large plus and
minus buttons are used to change the setting for MC, Bugs, and Ballast
- or you can drag the slider to change the settings. The glide ratio
and best glide speed are shown on the bottom of the screen and update
as you change the settings.
You can see details on the Nano4 he
https://www.cumulus-soaring.com/lxnav.htm#LXNAV-Nano4
I'll be making a Nano4 overview video which should be available
in less than 1 week he
https://www.cumulus-soaring.com/training.htm
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old February 28th 17, 06:06 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I'm still playing with Nano4 units. I just noticed that the unit can
display altitude AGL. Cool! It must have a built-in terrain elevation
database.
Paul Remde
On 28 Feb 2017 11:01, Paul Remde wrote:
Hi,
Best Regards,
Paul Remde
Paul Remde
LXNAV V8 (S8/V80/S80) Issues? [email protected] Soaring 10 November 6th 15 09:32 AM
New LXNAV S8 vario Paul Remde Soaring 5 October 12th 15 04:14 PM
LXNAV V3 Issues [email protected] Soaring 20 April 14th 15 05:49 AM
LXNav V7 Setup svelusive Soaring 9 February 22nd 15 04:29 PM
LXNAV V7 Paul Remde Soaring 2 November 2nd 11 12:31 AM
