Sideslip or crab immediately after takeoff on tow in crosswind?
Old March 6th 17, 05:48 PM posted to rec.aviation.soaring
Default Sideslip or crab immediately after takeoff on tow in crosswind?
I was wondering what the conventional wisdom is on whether to sideslip or crab the glider on takeoff under tow in a crosswind. I've always crabbed to follow the tow plane because of the low altitude and not wanting to risk catching a wingtip just after becoming airborne -and after a very short climbout you can sideslip without the risk of ground contact, though I usually continue to crab. However, doesn't crabbing the glider add a lot more drag to the towplane/glider combo?
Old March 6th 17, 06:05 PM posted to rec.aviation.soaring
No, a slip creates drag. A crab is clean.
Old March 6th 17, 06:16 PM posted to rec.aviation.soaring
Dan Marotta
Crab to stay over the runway until you have enough altitude to clear
obstacles, e.g., wind sock should the tug drift downwind. The tug
should also crab so you'll both be flying clean, as Tom said. After
you've got sufficient altitude, say 50-100 feet, slide back behind the tug.
Dan, 5J
Old March 6th 17, 08:57 PM posted to rec.aviation.soaring
This. I do keep the upwind wing a bit low until flying, then crab as needed to track over the ground even with the towplane until it's flying. Our towpilots turn upwind once about 200' AGL so getting back to the runway is easier in case of any issues on tow, this goes for the towplane as well as the glider.
Old March 7th 17, 12:07 AM posted to rec.aviation.soaring
Jim[_33_]
Dan, 5J
This is likely just a consequence of poor flying technique but I seem unable to sustain a crab behind the tow plane without holding a fair amount of up-wind rudder. The pull of the tow plane seems to pull the glider's nose out of the crab otherwise.
Old March 7th 17, 12:28 AM posted to rec.aviation.soaring
Dan Marotta
Maybe you're right. Since the 80s all of my gliders have had CG
releases so not much, if any, rudder was required to stay in the crab.
I can see that, with a nose release, you'd need some rudder to offset
the side load of the rope. Still not a problem.
Dan, 5J
Dan, 5J
Old March 7th 17, 12:29 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
tug.
Dan, 5J
Seems reasonable to me: if you're on track, i.e. your CG's velocity
vector is pointed at the tow-plane's CG, your nose hook is upwind of that
track and the towplane's tail hook is downwind of it. IOW the tension in
the rope is trying to rotate you round your CG so you point at the
towplane's tail. If the rope tension wins you'll be way out of position,
so it follows that you need to hold sufficient upwind rudder to prevent
the rope pulling you round and to keep your velocity vector aimed at the
towplane CG.
The amount of rudder deflection needed depends on what type of glider
you're flying.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 9th 17, 11:10 PM posted to rec.aviation.soaring
Dan, 5J
Jim, If you are holding rudder you are not crabbing. Crabbing is with the yaw string straight.
Old March 10th 17, 12:16 AM posted to rec.aviation.soaring
Jim[_33_]
Dan, 5J
Yes. That is my experience.
Do you crab or forward slip in X wind landings Jonathan St. Cloud Soaring 42 March 2nd 17 12:55 AM
Bob ! Get back to the shop IMMEDIATELY ! DRN Soaring 11 December 23rd 08 03:35 PM
Crab, slips, and crossed controls Amine Piloting 190 September 27th 08 07:59 PM
Head wind takeoff into rising hills, or crosswind takeoff to open space ?? P S Piloting 7 September 20th 07 07:29 PM
Seeking A&P to do a Long-EZ pre-buy inspection in OK immediately Shin Gou Home Built 2 March 10th 05 03:47 AM
