Cessna 195
Old July 30th 16, 04:12 AM posted to alt.binaries.pictures.aviation
Miloch
Default Cessna 195
Cessna 195
https://en.wikipedia.org/wiki/Cessna_195
The Cessna 190 and 195 Businessliner are a family of light single radial engine
powered, conventional landing gear equipped, general aviation aircraft which
were manufactured by Cessna between 1947 and 1954.
The 195 model was also used by the United States Air Force, United States Army,
and Army National Guard as a light transport and utility aircraft under the
designations LC-126/U-20
The Cessna 190 and 195 were Cessna's only postwar radial-engined aircraft. The
first prototype flew in 1945, after the end of World War II and both the 190 and
195 entered production in 1947.
The 195 was the first Cessna airplane to be completely constructed of aluminum
and features a cantilever wing, similar to the pre-war Cessna 165 from which it
is derived. The wing differs from later Cessna light aircraft in that it has a
straight taper from root chord to tip chord and no dihedral. The airfoil
employed is a NACA 2412, the same as used on the later Cessna 150, 172 and 182.
The 190/195 fuselage is large in comparison to other Cessna models because the
42" diameter radial engine had to be accommodated in the nose. There are two
rows of seats: two individual seats in the first row, with a comfortable space
between them and up to three passengers can be accommodated on a bench seat in
the second row.
The 190/195 has flat sprung-steel landing gear legs derived from Cessna's
purchase of the rights to Steve Wittman's Big X. Many have been equipped with
swiveling crosswind landing gear which allows landing with up to 15 degrees of
crab. While the crosswind gear simplifies the actual landing, it makes the
aircraft difficult to handle on the ground. The 195 is equipped with a
retractable step that extends when the cabin door is opened, although some have
been modified to make the step a fixed unit.
The aircraft was expensive to purchase and operate for private use and Cessna
therefore marketed them as mainly as a business aircraft under the name
"Businessliner".
The engines fitted to the 190 and 195 became well known for their oil
consumption. The aircraft has a 5-US-gallon (19 L) oil tank, with 2 US gallons
(7.6 L) the minimum for flight. Typical oil consumption with steel cylinder
barrels is 2 US quarts (1.9 L) per hour.
The Cessna 195 produces a cruise true airspeed of 148 knots (274 km/h) (170 MPH)
on a fuel consumption of 16 US gallons (61 L) per hour. It can accommodate five
people.
Including the LC-126s, a total of 1180 190s and 195s were built.
The 190 was originally introduced at a price of USD$12,750 in 1947 (equivalent
to $135,120 in 2015). When production ended in 1954 the price had risen to
USD$24,700 (equivalent to $217,648 in 2015) for the 195B. This compared to
USD$3,495 for the Cessna 140 two seater of the same period.
Role Light personal and business aircraft
National origin United States
Manufacturer Cessna Aircraft Company
First flight 1945
Introduction 1947
Primary users United States Army
Produced 1947-1954
Number built 1,180
Unit cost USD$12,750 (1947)
Developed from Cessna 165
The Cessna 190 and 195 are considered "one of the finest classics ever built" by
pilots and collectors and are much sought after on the used aircraft market
Specifications (Cessna 195)
General characteristics
Crew: one
Capacity: four passengers
Length: 27 ft 4 in (8.33 m)
Wingspan: 36 ft 2 in (11.02 m)
Height: 7 ft 2 in (2.18 m)
Empty weight: 2,100 lb (953 kg)
Gross weight: 3,350 lb (1,520 kg)
Fuel capacity: 75 US gallons (280 l; 62 imp gal)
Powerplant: 1 × Jacobs R-755 radial engine, 300 hp (220 kW)
Propellers: 2-bladed Hamilton Standard constant speed propeller
Performance
Maximum speed: 185 mph (298 km/h; 161 kn)
Cruise speed: 170 mph (148 kn; 274 km/h) at 70% power
Stall speed: 62 mph (54 kn; 100 km/h) power off, flaps 45°
Range: 800 mi (695 nmi; 1,287 km) at 70% power
Service ceiling: 18,300 ft (5,578 m)
Rate of climb: 1,200 ft/min (6.1 m/s)
Wing loading: 15.36 lb/sq ft (75.0 kg/m2)
Old July 30th 16, 04:51 AM posted to alt.binaries.pictures.aviation
Byker
Default Cessna 195
"Miloch" wrote in message ...
Cessna 195
No weather for a Cessna
Old July 30th 16, 05:58 AM posted to alt.binaries.pictures.aviation
Miloch
Default Cessna 195
In article , Byker says...
This is a multi-part message in MIME format.
Cessna 195
I took my first flying lessons in a 150...
Not much to 'em...just enough room for two people sitting shoulder to shoulder.
Cessna AT-17 Bobcat aka Cessna T-50 pics [14/21] - Cessna_UC-78B_USAF.jpg (1/1) Miloch Aviation Photos 0 July 20th 16 07:07 AM
Cessna AT-17 Bobcat aka Cessna T-50 pics [06/21] - Bamboo-cockpit1.jpg (1/1) Miloch Aviation Photos 0 July 20th 16 07:07 AM
Cessna AT-17 Bobcat aka Cessna T-50 pics [03/21] - Aircraft-Salvage-001-web.jpg (1/1) Miloch Aviation Photos 0 July 20th 16 07:07 AM
Cessna 310 pics [16/21] - Cessna 310 Twin-Engine Aircraft 1953.jpg (1/1) Miloch Aviation Photos 0 June 29th 16 11:41 PM
Cessna 310 pics [11/21] - Cessna-310B-N5349A-Songbird.jpg (1/1) Miloch Aviation Photos 0 June 29th 16 11:41 PM
