Republic P-47 Thunderbolt
Old August 2nd 16, 11:27 PM posted to alt.binaries.pictures.aviation
Miloch
Default Republic P-47 Thunderbolt
https://en.wikipedia.org/wiki/Republic_P-47_Thunderbolt
The Republic P-47 Thunderbolt was a World War II era fighter aircraft produced
by the United States between 1941–1945. Its primary armament was eight
..50-caliber machine guns, four per wing, and in the fighter-bomber ground-attack
role it could carry five-inch rockets or a bomb load of 2,500 pounds, more than
half the payload of the Boeing B-17 Flying Fortress bomber. When fully loaded
the P-47 weighed up to eight tons making it one of the heaviest fighters of the
war. The P-47 was designed around the powerful Pratt & Whitney R-2800 Double
Wasp engine which was the same engine also used by two very successful U.S. Navy
fighters, the Grumman F6F Hellcat and the Vought F4U Corsair. The Thunderbolt
was very effective as a short-to-medium range escort fighter in high-altitude
air-to-air combat but was also adept at ground attack in both the World War II
European and Pacific Theaters.
The P-47 was one of the main United States Army Air Forces (USAAF) fighters of
World War II, and served with other Allied air forces, notably those of France,
Britain, and Russia. Mexican and Brazilian squadrons fighting alongside the U.S.
were equipped with the P-47.
The armored cockpit was roomy inside, comfortable for the pilot, and offered
good visibility. A modern-day U.S. ground-attack aircraft, the Fairchild
Republic A-10 Thunderbolt II, takes its name from the P-47.
Role
Fighter-bomber
Manufacturer
Republic Aviation
Designer
Alexander Kartveli
First flight
6 May 1941
Introduction
November 1942[1]
Retired
1966, Peruvian Air Force
Primary users
Royal Air Force
French Air Force
Produced
1941–1945
Number built
15,660[2] or 15,677[3]
Unit cost
US$ 83,000 in 1945[4]
Variants
Republic XP-72
By the end of 1942, P-47Cs were sent to England for combat operations. The
initial Thunderbolt flyers, 56th Fighter Group, was sent overseas to join the
8th Air Force. As the P-47 Thunderbolt worked up to operational status, it
gained a nickname: the "Jug" (because its profile was similar to that of a
common milk jug of the time).[Note 4] Two Fighter Groups already stationing in
England began introducing the Jugs in January 1943: the Spitfire-flying 4th
Fighter Group, a unit built around a core of experienced American pilots who had
flown in the RAF Eagle Squadrons prior to the US entry in the war; and the 78th
Fighter Group, formerly flying P-38 Lightnings.
P-47 pilot Lt Col Francis S. "Gabby" Gabreski, 56th Fighter Group, leading ace
of the 8th Air Force
Beginning in January 1943, Thunderbolt fighters were sent to the joint Army Air
Forces – civilian Millville Airport in Millville, New Jersey in order to train
civilian and military pilots.
The first P-47 combat mission took place 10 March 1943 when the 4th FG took
their aircraft on a fighter sweep over France. The mission was a failure due to
radio malfunctions. All P-47s were refitted with British radios, and missions
resumed 8 April. The first P-47 air combat took place 15 April with Major Don
Blakeslee of the 4th FG scoring the Thunderbolt's first air victory (against a
Focke-Wulf Fw 190).
By mid-1943, the Jug was also in service with the 12th Air Force in Italy and
against the Japanese in the Pacific, with the 348th Fighter Group flying
missions out of Port Moresby, New Guinea. By 1944, the Thunderbolt was in combat
with the USAAF in all its operational theaters except Alaska.
Aerial warfare
USAAF P-47D "Razorback" configuration.
Initial response to the P-47 praised its dive speed and high-altitude
performance, while criticizing its turning performance and rate of climb
(particularly at low altitudes). The turbosupercharger in the P-47 gave the
powerplant its maximum power at 27,000 ft (8,230 m), and in the thin air above
30,000 ft (9,144 m), the Thunderbolt remained comparatively fast and nimble
relative to other aircraft.[41]
The P-47 first saw action with the 4th Fighter Group. The Group's pilots were
mainly drawn from the three British Eagle Squadrons who had previously flown the
British Supermarine Spitfire Mark V, a much smaller and much more slender
aircraft. At first they viewed their new fighter with misgivings. It was huge;
the British pilots joked that a Thunderbolt pilot could defend himself from a
Luftwaffe fighter by running around and hiding in the fuselage. Optimized for
high altitude work, the Thunderbolt had 5 feet (1.5 m) more wingspan, a quarter
more wing area, about four times the fuselage volume, and nearly twice the
weight of a Spitfire V.[42][43] One Thunderbolt pilot compared it to flying a
bathtub around the sky. When his unit (4th Fighter Group) was equipped with
Thunderbolts, ace Don Blakeslee said, referring to the P-47's vaunted ability to
dive on its prey, "It ought to be able to dive. It certainly can't climb."[44]
(Blakeslee's early-model P-47C had not been fitted with the new paddle blade
propeller). The 4th Fighter Group's commander hated the P-47, and his prejudices
filtered down to the group's pilots; the 4th had the fewest kills of any of the
first three P-47 squadrons in Europe.
Specifications (P-47D-30 Thunderbolt)
General characteristics
Crew: 1
Length: 36 ft 1 in (11.00 m)
Wingspan: 40 ft 9 in (12.42 m)
Height: 14 ft 8 in (4.47 m)
Wing area: 300 ft2 (27.87 m2)
Empty weight: 10,000 lb (4,535 kg)
Loaded weight: 12,731 lb (5,774.48 kg)
Max. takeoff weight: 17,500 lb (7,938 kg)
Powerplant: 1 × Pratt & Whitney R-2800-59B twin-row radial engine, 2,600 hp
(1,938 kW)
Performance
Maximum speed: 443 mph at 29,000 ft (713 km/h at 8,839 m)
Range: 800 mi combat, 1,800 mi ferry (1,290 km / 2,900 km)
Service ceiling: 43,000 ft (13,100 m)
Rate of climb: 3,180 ft/min (16.15 m/s)
Wing loading: 42.43 lb/ft2 (207 kg/m2)
Power/mass: 0.204 hp/lb (335 W/kg)
Armament
8 × .50 in (12.7 mm) M2 Browning machine guns (3400 rounds)
Up to 2,500 lb (1,134 kg) of bombs
10 × 5 in (127 mm) unguided rockets
Old August 2nd 16, 11:48 PM posted to alt.binaries.pictures.aviation
Savageduck[_3_]
On 2016-08-02 22:27:48 +0000, Miloch said:
As I said in another post, my father flew both P-38s and the P-47D. In
1943 the 49th Fighter Group had pretty much worn out their tired and
well used P-38Gs, so the 9th FS got P-47D replacements until fresh
P-38Js and P-38Ls arrived in late 1943 when the P-47Ds were reasigned
to other units.
Here he is with his P-47D "Bigasburd" at Dobodura, New Guinea, 1943.
Regards,
Savageduck
Old August 3rd 16, 02:16 AM posted to alt.binaries.pictures.aviation
Miloch
In article 2016080215481691745-savageduck1@REMOVESPAMmecom, Savageduck says...
This is a multi-part message in MIME format.
I posted them with your comment in mind....
052 - USAF Museum - Republic P-47D Thunderbolt.jpg - 052 - USAF Museum - Republic P-47D Thunderbolt.jpg [email protected] Aviation Photos 0 January 17th 16 05:34 PM
Udvar hazy Batch 6 [05/50] - Republic P-47D Thunderbolt DSC_3799.jpg (1/1) Indrek[_6_] Aviation Photos 0 November 21st 15 05:09 PM
Underwater 6 - Thunderbolt 02.jpg (1/1) Mitchell Holman[_8_] Aviation Photos 0 September 19th 14 02:51 PM
Republic P-47 Thunderbolt with Tonya Offer.jpg Square Wheels[_3_] Aviation Photos 1 February 18th 08 04:58 PM
P-47 Thunderbolt STEELHEALR Military Aviation 0 December 2nd 03 08:19 PM
