Messerschmitt Me 210
Old August 3rd 16, 06:42 AM posted to alt.binaries.pictures.aviation
Miloch
Default Messerschmitt Me 210
https://en.wikipedia.org/wiki/Messerschmitt_Me_210
The Messerschmitt Me 210 was a German heavy fighter and ground-attack aircraft
of World War II. The Me 210 was designed to replace the Bf 110; design started
before the opening of World War II. The first examples of the Me 210 were ready
in 1939, but they proved to have unacceptably poor flight characteristics from
serious wing planform and fuselage design flaws. A large-scale operational
testing program throughout 1941 and early 1942 did not cure the aircraft's
problems. The design entered limited service in 1943, but was almost immediately
replaced by the Messerschmitt Me 410 Hornisse ("Hornet"). The Me 410 was a
further development of the Me 210, renamed so as to avoid the 210's notoriety.
The failure of the Me 210's development program meant that the Luftwaffe was
forced to continue fielding the outdated Bf 110, despite mounting losses.
The Me 210 was a considerable departure from the 110, but used many of the same
parts. The main differences were a modified nose area that was much shorter and
located over the center of gravity, an internal bomb-bay, an all-new wing
designed for higher cruise speeds and a highly advanced remote-control defensive
armament system that gave the gunner a far wider field of fire. On paper, the Me
210's performance was impressive. It could reach 620 km/h (390 mph) on two 1,350
PS (1,330 hp, 990 kW) Daimler-Benz DB 601F engines, making it about 80 km/h (50
mph) faster than the Bf 110, and nearly as fast as single-engine fighters of the
era.
Role
Heavy fighter, ground-attack aircraft, fighter-bomber, dive bomber
Manufacturer
Messerschmitt, Dunai Repülogépgyár Rt.
First flight
2 September 1939
Introduction
1943
Retired
1945
Primary users
Luftwaffe
Hungary
Number built
90 finished and 320 partially completed in Germany, 272 in Hungary
Developed from
Bf 110
Variants
Me 410
Deliveries to front-line units started in April 1942, and the plane proved to be
even less popular with pilots. Production was stopped at the end of the month,
by which time only 90 had been delivered. Another 320 partially completed models
were placed in storage. In its place, the Bf 110 was put back into production.
Although the Bf 110 was now equipped with the newer DB 605B engines and greater
firepower, it was still an outdated design.
The Luftwaffe started receiving their Hungarian-built planes in April 1943, and
the Hungarians in 1944; when they entered service they were more than happy with
them. Production ended in March 1944, when the factory switched over to produce
the Bf 109G. By that time, a total of 267 Me 210C had been built, 108 of which
had been given to the Luftwaffe. They operated mostly in Tunisia and Sardinia,
and were quickly replaced by the Me 410.
Specifications (Me 210 - original fuselage)
General characteristics
Crew: 2 (pilot and gunner)
Length: 11.2 m (36 ft 9-7/8 in)
Wingspan: 16.34 m (53 ft 7? in)
Height: 3.7 m (12 ft 1-5/8 in)
Wing area: 36.20 m˛ (389.7 ft˛)
Empty weight: 7,070 kg (15,586 lb)
Max. takeoff weight: 9,706 kg (21,398 lb)
Powerplant: 2 × Daimler-Benz DB 601F liquid-cooled inverted V12 engine, 1,350 PS
(1,332 hp, 993 kW) each
Performance
Maximum speed: 564 km/h (304 knots, 350 mph) at 5,400 m (17,800 ft)
Range: 1,820 km (983 nmi, 1,130 mi)
Service ceiling: 8,900 m (29,200 ft)
Climb to 6,000 m (19,680 ft): 12.5 min
Armament
Guns:
2 × 20 mm MG 151/20 cannons
2 × 7.92 mm (0.312 in) MG 17 machine guns
2 × 13 mm (0.512 in) MG 131 machine guns (rear armament), one each in FDSL
131/1B remotely operated turret
Bombs: 2 × 500 kg (1,100 lb) or 250 kg (550 lb) or 8× 50 kg (110 lb) internal
Messerschmitt Me 262 pics [20/20] - messerschmitt-me-262-fighter-23.png (1/1) Miloch Aviation Photos 0 July 19th 16 04:00 PM
Messerschmitt Me 262 pics [19/20] - Messerschmitt-Me-262.jpg (1/1) Miloch Aviation Photos 0 July 19th 16 04:00 PM
Messerschmitt Me 262 pics [16/20] - Messerschmitt Me 262.jpg (1/1) Miloch Aviation Photos 0 July 19th 16 04:00 PM
Messerschmitt Me 262 pics [15/20] - Messerschmitt Me-262-1aU3 Schwalbe in Flight.jpg (1/1) Miloch Aviation Photos 0 July 19th 16 04:00 PM
Messerschmitt XC-44 zered Aviation Photos 10 January 28th 07 01:48 PM
