Alternative O-290 cylinders
Old June 19th 04, 07:23 AM
Gene Z. Ragan
Default Alternative O-290 cylinders
Hi,
I am wondering if V0-435 cylinders can be used as replacements for the
original 0-290 jugs.
This is for non-certified use. I have also heard of an O-320 cylinder
modification. If anyone could give me some advice, I would greatly
appreciate it.
Thanks!
Gene
Old June 19th 04, 11:01 AM
jls
"Gene Z. Ragan" wrote in message
m...
Hi,
appreciate it.
Thanks!
Gene
Go O-320 cylinders. There are shops who will modify your case for you.
Old June 19th 04, 05:09 PM
jls
m...
Hi,
appreciate it.
Thanks!
Gene
Here's something you may be interested in. I don't know him but you could
ask around the airport at Lakeland:
I'm a buyer and seller of Aircraft Engines and Parts for experimental,
homebuilt, and Airboats. I may have what you need as far as cases, cranks,
rods, cylinders, carbs, ect. Or you may have parts that interest me.
We also do machine work on O-290 cases to bore cylinder holes out for the
O-320 cylinders. Cylinder valve jobs are also done.
Send me a list of parts you have for sale or your needs. Catching by email
is probably faster.
Gary Barber
Lakeland, Florida
863-815-9782
E-Mail:
Alternative to Aero-NUT-Network RobertR237 Home Built 3 April 21st 04 09:29 PM
Alternative for Mitchell quartz clock w. ELT hands Rob Turk Home Built 0 March 1st 04 10:23 AM
0200A Higher Compression Cylinders? Boelkowj Home Built 3 December 16th 03 02:25 PM
0-320 cylinders Drew Dalgleish Home Built 9 December 8th 03 04:25 PM
0-235 lyc cylinders needed (3) Captain Dave Home Built 0 October 8th 03 08:00 PM
