First electric aerotow
Old April 4th 17, 02:42 PM posted to rec.aviation.soaring
Default First electric aerotow
See
http://www.military-technologies.net...speed-records/
Old April 4th 17, 04:53 PM posted to rec.aviation.soaring
Dan Marotta
That's very interesting! How does a hybrid electric aircraft work? Does
it use an internal combustion engine to drive a generator to charge
batteries to run the motor? It would be enlightening to see side by
side specifications.
On 4/4/2017 7:42 AM, wrote:
See
Dan, 5J
Old April 4th 17, 09:40 PM posted to rec.aviation.soaring
Andrew Ainslie
It's not hybrid, it's pure electric.
http://www.flyingmag.com/extra-unveils-electric-330le
https://arstechnica.com/cars/2016/12...airplane-ever/
Amazing little plane!!
Old April 4th 17, 10:02 PM posted to rec.aviation.soaring
Dan Marotta
The hybrid was mentioned elsewhere in the original article. They were
talking about commercial service...
Dan, 5J
Old April 4th 17, 10:26 PM posted to rec.aviation.soaring
jfitch
Power in an electric plane was solved long ago. It's duration that needs work - they mention having 15 minutes duration. That means it could aerotow maybe 6 gliders (and I wouldn't want to be the sixth...), then have to get recharged. No mention of the recharge time.
Old April 5th 17, 02:24 PM posted to rec.aviation.soaring
AS
In a previous life, I worked on AGVs (autonomous guided vehicles) which were powered by batteries. Instead of taking the vehicle out of service while recharging, we built a battery exchange station. The vehicle made the decision when it was time to go in for a new set based on remaining charge level and the task it had to finish. It would find the station, dock itself and within a few minutes, the old battery pack was replaced without human intervention. The vehicle then returned to its task.
If you want to make this plane economically viable as a tow plane and not have it sitting on the ground for any length of time to recharge, you must have a second or third set of batteries on the ground recharging and/or ready for a quick exchange.
Uli
Aerotow - Newsletter Tom[_9_] Soaring 3 September 5th 09 05:57 PM
Microlight aerotow....can it be done? Microlight Pilot Soaring 6 March 7th 07 11:22 PM
Teaching the aerotow Paul Moggach Soaring 5 September 12th 05 03:31 AM
Who said aerotow was expensive? Nick Olson Soaring 1 March 18th 05 05:23 PM
Aerotow Video Nick Gilbert Soaring 11 March 30th 04 05:31 PM
