https://en.wikipedia.org/wiki/Mikoyan-Gurevich_MiG-17
Mikoyan-Gurevich MiG-17 https://www.youtube.com/watch?v=YYu285Naqm0 Mikoyan-Gurevich MiG-17 Tribute https://www.youtube.com/watch?v=Q3sqGz48oCA The Mikoyan-Gurevich MiG-17 (Russian: ?????? ? ??????? ???-17) (NATO reporting name: Fresco) (China:Shenyang J-5) (Poland: PZL-Mielec Lim-5) is a high-subsonic fighter aircraft produced in the USSR from 1952 and operated by numerous air forces in many variants. It is an advanced development of the very similar appearing MiG-15 of the Korean War. The MiG-17 first saw combat in 1958 over the Straits of Taiwan and was used as an effective threat against supersonic fighters of the United States in the Vietnam War. It was also briefly known as the "Type 38, by U.S. Air Force designation prior to the development of NATO codes. While the MiG-15bis introduced swept wings to air combat over Korea, the Mikoyan-Gurevich design bureau had already begun work on its replacement in 1949 (originally the MiG-15bis45) in order to fix any problems found with the MiG-15 in combat. The result was one of the most successful transonic fighters introduced before the advent of true supersonic types such as the Mikoyan-Gurevich MiG-19 and North American F-100 Super Sabre. The design would ultimately still prove effective into the 1960s when pressed into subsonic dogfights over Vietnam against much faster planes which were not optimized for maneuvering in such slower speed, short-range engagements. Though the MiG-17 still strongly resembles its forebear, it had an entirely new thinner and more highly swept wing and tailplane for speeds approaching Mach 1. While the F-86 introduced the "all-flying" tailplane which helped controllability near the speed of sound, this would not be adopted on MiGs until the fully supersonic MiG-19. The wing had a "sickle sweep" compound shape with a 45° angle like the U.S. F-100 Super Sabre near the fuselage (and tailplane), and a 42° angle for the outboard part of the wings.[6] The stiffer wing resisted the tendency to bend its wingtips and lose aerodynamic symmetry unexpectedly at high speeds and wing loads.[3] Like its forebear, the MiG-17 inherited the major design deficit which could cause the fuel tanks develop to under-pressure if more than half the fuel had been used, which could easily lead to tank implosions, crushing the main fuselage of the aircraft mid-fight, with almost always fatal results. Roughly 30% of the fatal accidents of Soviet MiG-17 were attributed to this problem. Role Fighter aircraft National origin Soviet Union Manufacturer Mikoyan-Gurevich First flight 14 January 1950 Introduction October 1952 Status Limited service Primary users Soviet Air Force PLA Air Force Polish Air Force Vietnam People's Air Force Number built 11,060 Developed from Mikoyan-Gurevich MiG-15 Variants PZL-Mielec Lim-6 Shenyang J-5 MiG-17s were designed to intercept straight-and-level-flying enemy bombers, not for air-to-air combat (dogfighting) with other fighters.[10] This subsonic (.93 Mach) fighter was effective against slower (.6-.8 Mach), heavily loaded U.S. fighter-bombers, as well as the mainstay American strategic bombers during the MiG-17's development cycle (such as the Boeing B-50 Superfortress or Convair B-36 Peacemaker, which were both still powered by piston engines). It was not however able to intercept the new generation of British jet bombers such as the Avro Vulcan and Handley Page Victor, which could both fly higher. Even if the target had sufficient warning and time to shed weight and drag by dropping external ordnance and accelerate to supersonic escape speeds, doing so would have inherently forced the enemy aircraft to abort its bombing mission. However, the USAF's introduction of strategic bombers capable of supersonic dash speeds such as the Convair B-58 Hustler and General Dynamics FB-111 rendered the MiG-17 obsolete in front-line PVO service, and they were supplanted by supersonic interceptors such as the MiG-21 and MiG-23. MiG-17s were not available for the Korean War, but saw combat for the first time over the Straits of Taiwan when the Communist PRC MiG-17s clashed with the Republic of China (ROC, Nationalist China) F-86 Sabres in 1958. In 1958, MiG-17s downed a US reconnaissance Lockheed C-130 Hercules over Armenia, with 17 casualties. Specifications (MiG-17F) General characteristics Crew: One Length: 11.26 m (36 ft 11½ in) Wingspan: 9.63 m (31 ft 7 in) Height: 3.80 m (12 ft 5½ in) Wing area: 22.6 m² (243.3 ft²) Empty weight: 3,919 kg[47] (8,640 lb) Loaded weight: 5,350 kg (11,770 lb) Max. takeoff weight: 6,069 kg (13,375 lb) Powerplant: 1 × Klimov VK-1F afterburning turbojet Dry thrust: 26.5 kN (5,955 lbf) Thrust with afterburner: 33.8 kN (7,423 lbf) Performance Maximum speed: 1,145 km/h (618 knots, 711 mph) at 3,000 m (10,000 ft) Range: 2,060 km (1,111 nmi, 1,280 mi) with drop tanks Service ceiling: 16,600 m (54,450 ft) Rate of climb: 65 m/s (12,800 ft/min) Wing loading: 237 kg/m² (48 lb/ft²) Thrust/weight: 0.63 Armament 1x 37 mm Nudelman N-37 cannon (40 rounds total) 2x 23 mm Nudelman-Rikhter NR-23 cannons (80 rounds per gun, 160 rounds total) Up to 500 kg (1,100 lb) of external stores on two pylons, including 100 kg (220 lb) and 250 kg (550 lb) bombs, unguided rockets or external fuel tanks. (some versions equipped with 3x NR-23 cannons and 4x K-13 missiles * |
Mikoyan-Gurevich MiG-15 pics [20/21] - Mig15Takeoff05.jpg (1/1) | Miloch | Aviation Photos | 0 | August 19th 16 05:26 AM |
Mikoyan-Gurevich MiG-15 pics [14/21] - MiG-15_AP2011_0613_800.jpg (1/1) | Miloch | Aviation Photos | 0 | August 19th 16 05:26 AM |
Mikoyan-Gurevich MiG-15 pics [12/21] - mig-15_351iap.jpg (1/1) | Miloch | Aviation Photos | 0 | August 19th 16 05:26 AM |
Mikoyan-Gurevich MiG-15 pics [02/21] - 192-Mig-15.jpg (1/1) | Miloch | Aviation Photos | 0 | August 19th 16 05:26 AM |
Mikoyan-Gurevich MiG-15 | Miloch | Aviation Photos | 0 | August 19th 16 05:22 AM |
