VOX intercom and ANR headsets
Old June 20th 04, 11:31 AM
Philippe
Default VOX intercom and ANR headsets
Hello,
With two ANR headsets, is a vox intercom still useful?
Thanks
Philippe Vessaire Ò¿Ó¬
Old June 20th 04, 02:14 PM
Dave S
Yes
Philippe wrote:
Hello,
Thanks
Old June 20th 04, 03:30 PM
Charlie England
Dave S wrote:
Yes
Philippe wrote:
Hello,
Thanks
Two different functions.
ANR listens to noise in the cockpit (actually in the earpiece) using its
own mics mounted in the earpieces & generates an inverse signal to
cancel it out. It ignores signal coming from the microphone at your mouth.
VOX (voice operated switch) listens to the microphone & only allows the
intercom to send the sound from the mic to the earphones when the
'noise' exceeds a level set by the operator using the 'squelch' control
on the intercom. 'Squelch' is set so that the addition of voice to
cockpit noise is sufficient to 'break squelch' & allow the mic signal to
flow through the intercom to the headphones.
When the intercom breaks squelch, you will hear cockpit noise along with
voice in the headsets, even with ANR.
Charlie
Old June 24th 04, 03:01 AM
Bill Gates
Check out Flight Tech intercoms at http://www.flighttech.com/. It is an ANR
intercom and you can still use ANR headsets with it.
"Philippe" wrote in message
Hello,
Thanks
