Use of Statics
Old December 28th 03, 12:31 PM
Robin Birch
Default Use of Statics
Hi,
I have an Astir CS77, a fine but venerable glass machine. I am
refurbishing the cockpit, panel, and so on.
Having got the panel to bits I am looking at the best way of putting it
all back together. So:
1) I have two static systems, a forward system and a rear one. In the
current configuration these are connected to different instruments. Is
this correct and if so, which instruments should be grouped together on
which static system? Or, should I have all of the static ports (4 in
total, 2 forward and two rear) commoned up?
2) All of the gliders I have flown to date use the cockpit air to drive
the altimeter. In other words the connector on the back of the
instrument has nothing connected to it. Is this ok or is it better to
connect the altimeter to the static system?
Regards
Robin
Robin Birch
Old December 28th 03, 04:13 PM
John Galloway
The ASI has to be connected to the static (and pitot)
source specified in the aircraft manual if you want
to be flying with a valid C of A - and hence insurance.
John Galloway
At 12:54 28 December 2003, Robin Birch wrote:
Hi,
I am
way of putting it
a rear one. In the
instruments. Is
grouped together on
static ports (4 in
back of the
or is it better to
Regards
Robin
Robin Birch
Old December 28th 03, 05:17 PM
edwin
1) a lot of gliders have 2 static systems. Most of the time your manual can
tell you what static should be used for what instrument (my ventus manual
does so).
2) always connect your instruments. Otherwise dirt can get in the
instrument.
"Robin Birch" schreef in bericht
Hi,
Regards
Robin
Robin Birch
