https://en.wikipedia.org/wiki/Martin_B-57_Canberra
The Martin B-57 Canberra is an American-built, twinjet tactical bomber and reconnaissance aircraft that entered service with the United States Air Force (USAF) in 1953. The B-57 is a license-built version of the British English Electric Canberra manufactured by the Glenn L. Martin Company. Initial Martin-build models were highly similar to their British-built counterparts; Martin later modified the design to incorporate larger quantities of US-sourced components and produced the aircraft in several different variants. The B-57 Canberra holds the distinction of being the first jet bomber in U.S. service to drop bombs during combat. The Canberra was used extensively during the Vietnam War in a bombing capacity; dedicated versions of the type were also produced and served as high-altitude aerial reconnaissance platforms (the Martin RB-57D Canberra), and as electronic warfare aircraft. The B-57 Canberra was also sold to export customers abroad, further combat use was seen by the Pakistani Air Force during the Second Kashmir War and the Indo-Pakistani War of 1971. In 1983, the USAF opted to retire the type; the B-57 Canberra's retirement marked the ending of the era of the tactical bomber that had its beginning with the British World War I De Havilland DH-4 bomber. The three remaining flightworthy WB-57Fs are technically assigned to the NASA Johnson Space Center, next to Ellington Field in Houston, as high-altitude scientific research aircraft, but are also used for testing and communications in the U.S. and Afghanistan. Role Tactical bomber Manufacturer Martin First flight 20 July 1953[1] Introduction 1954 Retired 1983 (USAF) 1985 (Pakistan) Status Retired (3 still used by NASA[2]) Primary users United States Air Force Pakistan Air Force Republic of China Air Force Number built 403 Unit cost US$1.26 million (B-57B)[3] Developed from English Electric Canberra Variants Martin RB-57D Canberra Developed into Martin/General Dynamics RB-57F Canberra The B-57A was not considered combat-ready by the USAF and the aircraft were used solely for testing and development. One of the aircraft was given to the National Oceanic and Atmospheric Administration (NOAA) which fitted it with a new nose radome and used it to track hurricanes. The aircraft was placed into limited production. Particularly contentious were the cockpit arrangement and the lack of guns, the Canberra having been designed as a high-speed, high altitude bomber rather than for close air support. The definitive B-57B, which introduced numerous improvements, made its first flight on 18 June 1954. The aircraft initially suffered from the same engine malfunctions as the RB-57As and several were lost in high-speed low-level operations due to a faulty tailplane actuator which caused the aircraft to dive into the ground. The USAF came to consider the B-57B as being inadequate for the night intruder role and thus Martin put all aircraft through an extensive avionics upgrade in response. Regardless, by the end of 1957, the USAF tactical squadrons were being re-equipped with supersonic North American F-100 Super Sabres. The complete retirement was delayed, however, by the start of the Vietnam War. Specifications (B-57B) General characteristics Crew: 2 (pilot,navigator ) Length: 65 ft, 6 in (20.0 m) Wingspan: 64 ft 0 in (19.5 m) Height: 14 ft 10 in (4.52 m) Wing area: 960 ft² (89 m²) Empty weight: 27,090 lb (12,285 kg) Loaded weight: 40,345 lb (18,300 kg) Max. takeoff weight: 53,720 lb (24,365 kg) Powerplant: 2 × Wright J65-W-5 turbojets, 7,220 lbf (32.1 kN) each *Zero-lift drag coefficient: 0.0119 Drag area: 11.45 ft² (1.06 m²) Aspect ratio: 4.27 Performance Maximum speed: Mach 0.79 (598 mph, 960 km/h) at 2,500 ft (760 m) Cruise speed: 476 mph (414 knots, 765 km/h) Stall speed: 124 mph (108 knots, 200 km/h) Combat radius: 950 mi (825 nm, 1,530 km) with 5,250 lb (2,380 kg) of bombs Ferry range: 2,720 mi (2,360 nm, 4,380 km) Service ceiling: 45,100 ft (13,745 m) Rate of climb: 6,180 ft/min (31.4 m/s) Wing loading: 42 lb/ft² (205 kg/m²) Thrust/weight: 0.36 Lift-to-drag ratio: 15.0 Armament Guns: 4× 20 mm (0.787 in) M39 cannon, 290 rounds/gun Bombs: 4,500 lb (2,000 kg) in bomb bay, including nuclear bombs 2,800 lb (1,300 kg) on four external hardpoints, including unguided rockets Avionics APW-11 Bombing Air Radar Guidance System SHORAN bombing system APS-54 Radar Warning Receiver * |
048 - USAF Museum - Martin EB-57B Canberra.jpg - 048 - USAF Museum - Martin EB-57B Canberra.jpg | [email protected] | Aviation Photos | 0 | January 17th 16 05:34 PM |
Cockpits 10 - Martin Canberra.jpg (1/1) | Mitchell Holman[_8_] | Aviation Photos | 0 | May 27th 15 01:04 PM |
Historic Bombers Martin B-57F Canberra Bomber USAF in Flight.jpg (1/1) | J.F. | Aviation Photos | 3 | October 27th 07 04:44 AM |
Martin B-57B Canberra | J.F. | Aviation Photos | 0 | April 6th 07 02:24 AM |
